Aftermarket Sedan Exhaust Compilation
Old Mar 7, 2012 | 12:55 AM
  #886
X-Rated's Avatar
Originally Posted by ryanm8
It would sound exactly like the coupe if you had a coupe midpipe along with it. The problem with getting the Flowmaster 80 series on the sedan is that it sits horizontal in relation to the car. So there's not really anywhere that it would fit, other than the rear where the spare tire well is. Which would mean you would have to cut the spare tire well out.
awesome thanks so much but deff not worth all that, im going to look into other exhaust systems . . . Appreciate the help !
Old Mar 7, 2012 | 02:10 AM
  #887
Songle6MT's Avatar
Originally Posted by Beebo
whats causing the rasp?
I don't know? It isn't that bad really, I just didn't want it to be raspy. I guess that's what I get for having HFC and 3" exhaust. I almost think I have a very small exhaust leak somewhere but it's not very evident if there is.
I'll get a video up under load and see what you think about how it sounds.
Old Mar 7, 2012 | 02:17 AM
  #888
Beebo's Avatar
did you use oem exhaust gaskets? when i installed my labree resonated test pipes, i had a hissing noise and it was from the cheap gaskets i used... replaced them with OEM and the noise was gone
Old Mar 7, 2012 | 02:42 AM
  #889
Songle6MT's Avatar
I used gaskets that were included. If I do have a leak I am assuming it would be at the gaskets that the HFC meet the headers with. However when I listen under the car with it running I don't hear a hissing or leak of any sort. I've listened a few times for a leak.
When I put my sway bars on in the spring I might get adventurous and get new gaskets for those just to make sure.
Old Mar 7, 2012 | 10:08 PM
  #890
BRANDO23's Avatar
MR TPs Jus got in I'm guessing these new ones came with cell fixes in them? Or should I Jus get the four 18mm non foulers 04 sedan idk if its 04. Somthin or not.
Old Mar 7, 2012 | 11:21 PM
  #891
Songle6MT's Avatar
See if the CEL comes on. If it does get some non foulers...
Old Mar 8, 2012 | 06:30 PM
  #892
Nortex's Avatar
Which is louder? Coupe mid with muffler delete or resonator delete with stock rear. I ask because I want to be able to change as I please. When its just me running out of town more is better and when I have the family I want to keep it silent
Old Mar 8, 2012 | 06:33 PM
  #893
JaE35's Avatar
Moderator
G35 Sedan
Muffler delete sounds absolutely redic. do not recommend doing that...cutting out the resonator on the mid would introduce nasty rasp and also sound terrible
Old Mar 8, 2012 | 06:47 PM
  #894
Nortex's Avatar
Its for like 2 days. I wont cut my coupe mid but was going to do my stock sedan mid with a straight pipe or a resnator off my old tahoe
Old Mar 8, 2012 | 06:50 PM
  #895
JaE35's Avatar
Moderator
G35 Sedan
I have an extra 4" single that sounds mean with the coupe midpipe i took off recently for the tanabe back-end
Old Mar 8, 2012 | 06:51 PM
  #896
Nortex's Avatar
excuse my dumbness. 4" single pipe? any clips
Old Mar 8, 2012 | 06:55 PM
  #897
JaE35's Avatar
Moderator
G35 Sedan
minus the rasp from this guy's megan test pipes
Old Mar 8, 2012 | 08:10 PM
  #898
Nortex's Avatar
Nah man looking for something close to stock just alittle louder than my coupe mid. Is that guys held up with wire?
Old Mar 9, 2012 | 12:02 PM
  #899
Abax84's Avatar
^ You could go with a smaller resonator. Coupe mid is small, but you can go smaller. And HR-Y Pipe.
Old Mar 9, 2012 | 10:21 PM
  #900
Nortex's Avatar
Whats the smallest res ?
