Possible to break into 13s NA in an 03 sedan?
Old Dec 1, 2007 | 07:14 PM
gEE805's Avatar
Originally Posted by black_sedan
well, there's another post on here where someone was running low 14s by neutral dropping it. im sure 13 sec timeslips arent that hard to come by.
thats gonna mess your tranny up. Auto werent ment to do it... Your gonna mess up the torque convertor
Old Dec 1, 2007 | 07:17 PM
OCG35's Avatar
Originally Posted by ttrank
+1
I ran ~2.0 60' on my 20's on a warm night.
glad i'm not the only one that read it wrong... he said he did 2.7 on street tires, but he would have sub 2 "with DR"...
Not verbatim, but I believe thats what he meant...
2.7 though?....
Old Dec 1, 2007 | 07:18 PM
OCG35's Avatar
nah... he "heard" someone kicked A$$ that way! Must be the way to go!
Old Dec 1, 2007 | 07:32 PM
OCG35's Avatar
Clearly I’m using “Child Psychology/Reverse psychology"…
At the Track – for best performance:
1) Use a long ram intake
2) Don’t bother with after market shielded intakes or a Z-Tube (it just makes the straight air flow too cold)
3) If AT, ALWAYS break torque – pull the stop lamp fuse (you get better smoke, and the ECU won't alter your power)
4) If #2 doesn’t work, 2nd worst (I’m mean next best) Neutral drop
5) Drop tire pressure to sub 25 psi
6) Hi-flow exhaust is just loud… stay with stock – you’ll never notice the difference without an ECU tune anyway
7) Don’t get an ECU tune because all the above is a waste of money
8) Don’t go FI, bang for the buck you’re are better off N/A
Okay… children, that about covers it… now go on and do exactly as I didn’t say!
Old Dec 1, 2007 | 07:35 PM
Skaterbasist's Avatar
Retired SuperMod
Easiest way of knowing if you and the track are 13 second capable:
Run it stock. If you yield low 14's, 13's should be easy with full NA. The tracks around my area are not so great. So 13's is a much bigger deal here than in the tracks at the east coast (for instance).
Old Dec 1, 2007 | 07:40 PM
OCG35's Avatar
I guess we'll never know after today’s debacle! At least you got your beauty sleep (unless you still ugly ) J/K -
Old Dec 2, 2007 | 01:40 AM
wootwoot123's Avatar
It sounds like I am reaching for something that is not possible. Would an upgraded torque converter help much? How about an LSD?
Old Dec 2, 2007 | 01:54 AM
OCG35's Avatar
both would help a bunch - but to the tune of over 2K... there are other things you could do first, Skaterbasist was right... I was just giving him **** because he overslept and didn't show up to the closed track day today! (Friggin' Notradamus!)
It's possible to run 13s bone stock with the right tires on a day like today... BUT WE'll NEVER KNOW!!!!!! F-ing Autoclub Raceway personnel!!!! Damn A-Holes!!!!!!
I mean, we'll know next month
Old Dec 2, 2007 | 02:41 AM
abailey269's Avatar
Possible with those mods?..... Yes. Likely?....... No.
So the question remains, how to do it?
With those mods (Spacer, HFC, Pop/Ztube) you should trap 99-100mph wich is good enough for high 13's with a 2.0 or less 60'. To get that 60' you will need a good set of tires (Drag radials on stock rims is fine).
I would recommend a tune after those mods (should get you another 10-15whp and open up the power band -- +1-2mph in the 1/4)
Old Dec 2, 2007 | 03:09 AM
DaveB's Avatar
Best post yet.
Where do you live and I'll tell you if you've got a shot at 13s with an NA sedan.
Old Dec 2, 2007 | 08:09 PM
AS007's Avatar
I have a 2005 6mt Sedan with Injen CAI, Mrev2, 5/16" spacer, headers, test pipes, borla cat-back, and a 285/30/19 in the rear for some extra grip. My best time was a 13.78 with a 2.29 60 ft. time my launch could have been much better. Trapped 104.364mph, 52 degress F.
Old Dec 2, 2007 | 08:15 PM
awong's Avatar
i think this shiet will work probably 13 mids
Old Dec 2, 2007 | 09:09 PM
VQ Hotness's Avatar
Originally Posted by OCG35
2.7 60' with DR?>.... the DRs didn't do you
any good...
Ooops... nevermind - my appologies - I re-read and understood you to say 2.7 "without DR"...
Decent track prep + decent weather + decent launch + avg pwr + DR = sub 2.0 60' easily! first 4 without DR = sub 2.0!
DR to me is like NOS (a bit of a cheat)... unless you run NOS and/or have DRs at the stop light, I'm gonna beat you to the fwy entrance
Yes i could prob get my 60' Down a little more if i had a little more time on the track, and if i did'nt have as much neg camber in the rear as i do.
Luisgalvan33
Jul 19, 2018 08:16 PM
rsingerG35
Interior
Aug 13, 2015 05:01 PM
