Hi, new to forum (!)
Old Dec 9, 2007 | 05:59 AM
emerson's Avatar
Hi, new to the forum. Quick question i have a 05 g35 sedan. On the cluster theres a (!) sign on the left side. The ! is inside a O. The sign came on earlier, and went off, wondering what that sign means. Tried searching couldnt find anything....
TIA
Old Dec 9, 2007 | 09:05 AM
perry05G35's Avatar
That's your tire pressure sensor it's telling you that one of your tires is losing tire pressure for whatever reason. Do a visual inspection of your tires for nails or tire pressure lower than 33 psi.
Old Dec 9, 2007 | 09:07 AM
risingson's Avatar
also.. correct me if im wrong, but alot of them- probably in the earlier models, dont work right and will come on when your tire pressure is fine.
Old Dec 9, 2007 | 12:00 PM
Jedunnigan's Avatar
Yea, mine comes on during long trips and when I stop at a gas station to check they are all perfectly fine.
Seems to turn on when I hit a bump or something in the road ???
Old Dec 9, 2007 | 12:36 PM
ttrank's Avatar
Grocery getter
Hello and welcome
Old Dec 9, 2007 | 03:32 PM
geesteezd's Avatar
^+1 its ur TPS
welcome!
Old Dec 9, 2007 | 04:13 PM
frog's Avatar
welcome!
Old Dec 9, 2007 | 07:14 PM
miltoda's Avatar
Really 33 psi? My 06 sedan says to put 30 psi in the tires on the sticker that's visible when you open the driver's door. I think he's got probably mid to low 20 psi for it to go off.
Old Dec 9, 2007 | 07:17 PM
06g35meister's Avatar
when you get new tires they can get messed up, you need a TPMS rebuild kit from any reputable tire shop, that shoudl fix the problem, mine were 4.50 for 1, so like $18
carid
Aug 22, 2016 01:34 AM
Jiggerjuice
Aug 26, 2015 09:00 AM
