Aluminum Sport Pedals
Old Jan 6, 2008 | 03:04 PM
Allenzi35's Avatar
Originally Posted by Jason@Riverside
Part number? Possible they could have given you the FX pedal which look similar and close in part numbers...
The part # on my order slip says: Footrest Assy INF 67840-CD01A
Is that the right one?
Thanks
Old Jan 7, 2008 | 09:05 AM
chrisg_101's Avatar
Mine covers the fuse panel as well. How often do I really need to get in there, not very. If you do have to just pull the footrest off.
Old Jan 7, 2008 | 04:33 PM
Qclass's Avatar
pedal covers are kinda a waste of money.
Old Jan 7, 2008 | 05:07 PM
g35freak86's Avatar
Ok, then don't buy them.
Old Jan 7, 2008 | 08:49 PM
Jason@Riverside's Avatar
Thats the correct part number...
but what is the part number on the part baggy its self?
Old Jan 7, 2008 | 10:20 PM
Allenzi35's Avatar
The part # on the baggie is exactly the same number thats on the order slip. It says Nissan on the bag.
Old Jan 9, 2008 | 10:46 AM
Andyl's Avatar
G35freak86 Try Using Some Silicone To Hold The E-brake Pedal On Just Take Off The Little Pedal And Push It Into The New Pedal Let Harden And Install Worked On Mine And Still Going Strong
Old Jan 9, 2008 | 01:40 PM
g35freak86's Avatar
^ hmm thats a great idea. so use the OEM rubber e brake pedal? Just glue that on the back o fthe new pedal? I'll give it a try. Seems like it would work well
Old Apr 1, 2010 | 08:20 PM
forzaG35's Avatar
I know it's a 2 year old thread. But I am having the exactly same problem. I have a 06 coupe 5at non-sport and I ordered parts from riverside Infiniti. The part number is Footrest Assy INF 67840-CD01A. I asked local Infiniti dealer to put them on for me. The brake and gas pedals are dead on, but the foot rest is totally mis-matched. My footrest seems wider then the allumina footrest. The guy from Infiniti asked me to change the part. He thinks it's the wrong part. Is it correct? Have you guys figured it out? Or maybe jason@riverside can explain this to me? Thanks!
Old Apr 1, 2010 | 08:59 PM
Mustang5L5's Avatar
That's the pedal I have too when i ordered from EverythingG35
Haven't installed yet...doing them and my splash gaurds this weekend.
Old Apr 1, 2010 | 11:40 PM
iTzTeddy's Avatar
I recently just installed them, and it does look different than stock, depending on differnet angles, but it is the same exact size.
Old Apr 2, 2010 | 11:04 PM
wompem's Avatar
Originally Posted by g35freak86
What did everyone use to keept he E brake pedal on (if you have 5AT). I used an epoxy and it held strong for about 2 weeks but then today it fell off. Could be because it's 18 degrees out, but still. If anyone reccommends anything please let me know. Thanks
I got a small bolt with a countersunk head. There's a hole in the part that the pedal attaches to. The countersunk sits inside the center divot in the pedal, so no raised surface. Then a nut on the back side. Snug everything tight (and alight the slot in the countersink) and everything's fine so far.
Old Apr 3, 2010 | 12:52 PM
G35xChicago's Avatar
ebrake pedal: drilled a hole through the middle and used a black bolt. Cant even tell.
dead pedal: should snap fairly easily assuming you have the correct one.
Old Apr 3, 2010 | 02:58 PM
Mustang5L5's Avatar
I just finished installing mine. Was easier than I thought...even the brake pedal was easy.
Dead pedal fit perfect. Don't even need the dealer to install, the gas and dead pedal took 5 mins each. Brake pedal took about 10 to work around and get the rubber lip folded over.
I didn't do the dead pedal yet. I got some good epoxy at work i want to use that will never come off.
Now off to do my splash guards
Old Apr 3, 2010 | 03:32 PM
  #30
forzaG35's Avatar
Glad to hear you put on those pedals already Mustang5L5. Mine dead pedal has this left side extra margin comes out makes it looks different in size(narrower) compare to the non-sport pedal. I doubt it's for FX45. Where did you order from?
Here is mine look like,
http://cgi.ebay.com/ebaymotors/INFIN...Q5fAccessories
