!!Look here before starting a new thread!! 2003-2006 Sedan FAQ's
Rating: Thread Rating: 9 votes, 5.00 average.
Old Jul 17, 2016 | 12:44 AM
  #511
Black_Out's Avatar
Can't find this answer anywhere, but I have a 04' G sedan with the sport suspension. Is the sport suspension from a coupe the same? I need new struts and shocks and all I find is the ones from the coupe. I installed the G/Z spring set up and realized at the end that the rear shocks are bad.
Old Jul 17, 2016 | 12:26 PM
  #512
NFSP G35's Avatar
? = 2B || !2B
No, they're not exactly the same, but they're interchangeable, and the shocks from the coupe would be better for you anyway since you have coupe springs.
Matching the spring to the shock/strut is always the best way to go.
Old Jul 17, 2016 | 01:19 PM
  #513
Black_Out's Avatar
Thank you for the response. But since I have the Z springs in the back the Z shocks would lower the car more than I would like. I'm trying to keep the same height as with the sedan sport strut and shocks while using the G/Z combo. Basiclly looking for compatible struts/shocks to sedan sports. All the ones I find are coupe sport. Thx
Old Jul 17, 2016 | 04:25 PM
  #514
NFSP G35's Avatar
? = 2B || !2B
Springs determine ride height. Not shocks or struts.
Old Jul 18, 2016 | 08:34 AM
  #515
Texasscout's Avatar
If you have coupe or Z springs ( I prefer Z front and coupe back, to levels the car) and sedan shocks, unless the shocks are aftermarket (like TOKIKO) they will start leaking in 6 months.
Old Jul 18, 2016 | 09:53 AM
  #516
NFSP G35's Avatar
? = 2B || !2B
^ Since his shocks are the sport (red) ones, they might last a little longer, but it's still better to run shocks designed for the springs.
Shock pistons have an ideal range of motion. If you lower the car without changing your shocks, the shocks will be outside that tolerance and could be more prone to bottoming out (which will destroy them quickly)
That's why your best bet is always to swap the springs and shocks/struts together instead of springs only.
Again, it's the springs that determine the ride height, not the shocks (unless you were so far out of tolerance that it bottomed the shock before compressing the spring, which would be pretty much the worst setup in history LOL)
Answering your original question; if you have coupe springs in the front and Z springs in the back, then perfectly matched shocks/struts would be best... (Z struts, coupe shocks in the back)
However, coupe shocks/struts all around would be a close second, especially considering that some of the coupes and Zs actually have the same exact front springs anyway.
Old Jul 18, 2016 | 09:16 PM
  #517
Black_Out's Avatar
Thanks for all the help guys...I will just match the springs with the struts/shocks. Also to clear up post #513 I do have Z springs in the front and coupe in the rear. Also after riding around today the rear has evened out equally, but still replacing all 4 corners.
Old Jul 18, 2016 | 09:28 PM
  #518
Black_Out's Avatar
I have 235/50 tires so there's still a little gap but 18"coming soon.
Attached Thumbnails !!Look here before starting a new thread!!  2003-2006 Sedan FAQ's-photogrid_1468891118640.jpg
Old Jul 19, 2016 | 06:52 AM
  #519
Texasscout's Avatar
I run 245 40 19s on 8" -35 offset wheels (-30 is perfect but hard to find). It's the same rolling circumference as stock (18" sport) so the speed-o is correct. The only disadvantage is that 19" tires are harder to find and more expensive than 20s.
Old Dec 11, 2021 | 11:00 PM
  #520
3000vr4tt's Avatar
Anyone confirm that the ISR long tube headers fit the awd sedan guys? I got an 05
Old Dec 30, 2022 | 11:28 AM
  #521
jk319's Avatar
Infiniti G35 Sedan Automatic no mods
Noise when gas is let off
My 2005 G35 RWD sedan started making noise after front brake pads and rotors replaced and instrument cluster removed (that's right - finally pulled the trigger on having it repaired to fix fuel gauge). These two jobs were done back to back, so I can't put a finger on any one job. Noise occurs when driving and letting off the gas pedal. Noise comes from the front of the car and it seems like it comes from the driver's side. It sounds like I have a loose part in the engine compartment/suspension.
Any idea??
Old Jan 1, 2023 | 12:19 PM
  #522
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Does it feel weird when you press on the brakes?
Old Jan 1, 2023 | 12:52 PM
  #523
jk319's Avatar
I found out that my alternator wasn't working and didn't charge the battery. Car lost power and I was stranded on the road. So, it has to be something that works off of alternator or if there is enough electrical power.
Muski_G
Dec 1, 2023 11:11 AM
Jusseth
Sep 13, 2020 12:25 PM
joedaddy1
Jul 28, 2015 02:58 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
