350z sway bars WORTH IT ???
Im looking into getting some sway bars and from doing some searching i read that the 03-06 350z and G35 coupe and G 35 sedan are inter changable.
Some one correct me if im wrong, but is getting a 350z sway bar set F & R .
worth it? VS a say hotchicks or stillen ?
I remember when i had my BMW I had 325 sways and upgraded to 330i sways and it made a diffrence.
Not a perfect answer, but gives you after market sway bar specs. I'm not sure what the specs are on the stock ones. If I wasn't lazy I could measure the stock G35 ones I have in the garage.
https://g35driver.com/forums/showthr...y+bar+diameter
well they aren't.
"G35sedan"
Group A
03-04 350Z all trim levels (car's without the revised suspension ONLY)
03-06 G35 coupe (all USDM production with oem 17 and 18" wheels)
03-04 G35 sedan (sport and non sport suspension's
All group A car's have the following oem sway bar specs
34mm front 21mm rear
hollow wall construction 5mm in thickness (courtesy of tomsn16)
Torsional rigidity Front: 1130lbs Rear:385 (courtesy BJ EVO350)
Group B
04.5-06 350Z all trim levels (car's with the revised suspension)
05-06 G35 coupe (all USDM production with oem 19" wheels)
04-06 G35 sedan (sport and non sport suspensions)
hollow wall construction 7mm front (courtesty tomsn16) 5mm rear
net change in front bar strength from 2mm increase in wall thickness
+17% (courtesty of tomsn16)
Example: The nismo sway bars are 18% stiffer front than Group A cars and -1% stiffer rear. They are only 1% stiffer front than Group B cars.
"G35sedan"
Group A
Group B
I definitely noticed a big difference in body roll before and after installation of Stillen sways in my car. Huge improvement especially when taking a few twisties or fast corners but beware of the sticker price on Stillen products. I've seen a couple people on the forum though selling Stillen sways in the classifieds section for half the original price or more.
i just picked up a 04.5 350z complete suspension for $150 shipped
I asked if he had the sway bars and said he threw them away
oh well ,lowering it should help a bit lets see what happens , besides i need to see if the rear will clear my 245-45 -18 in the rear , i know the 225-45-18 up front clears.
![Biggthumpup](https://g35driver.com/forums/images/smilies/biggthumpup.gif)
![EEK!](https://g35driver.com/forums/images/smilies/eek.gif)
Originally Posted by Hybrid_DET
well they aren't.
"G35sedan"
Group A
Group B
"G35sedan"
Group A
Group B
