WHO here has installed coupe seats
Old Jan 30, 2008 | 02:20 PM
dklau33's Avatar
Nice job. The sedan seats should have been like this in the first place, or at least in the 6MT.
Old Jan 30, 2008 | 02:27 PM
ttrank's Avatar
Grocery getter
All sedans!
I have no idea why they chose to put those flat seats in the sedan. They suck...
Old Jan 30, 2008 | 04:25 PM
MightyG35's Avatar
Tim, did you have to customize the mounting points, or did you just switch out the whole rail?
Old Jan 30, 2008 | 04:40 PM
ttrank's Avatar
Grocery getter
Rails are the same. They bolt right in but as Hybrid said above the seats sit lower. It's not a problem for the driver because that part's power but you should raise the pass side up a bit. You can use washers or something like that to move it up a bit but if you want to go way up you will need longer bolts.
Old Jan 30, 2008 | 10:27 PM
Tunerz_Store's Avatar
For the spacers I actually used a 3/8" diameter metal coupling from the plumbing section in Home Depot. It set the back about right at an inch. I used 60mm long bolts (m10x1.25) and in the front I used hard plastic spacers that measure just shy of 1/2". I used 40mm long bolts in the front (m10x1.25). I also used a 3/8" washer on the bolt head.
Tim, I did get coupe headrests, but I think the sedan ones fit better and are positioned forward slightly more.
The seats make u feel like you are in a completely different car. Kind of weird.
Old Jan 31, 2008 | 12:26 PM
ttrank's Avatar
Grocery getter
I know what you mean. It's amazing how much better they are!
Did you get the bolts at home depot too? I might do that this weekend to raise mine up a little more.
Congrats again! I know you are loving it!
Old Feb 6, 2008 | 12:30 PM
sliderg35's Avatar
Where did you guys get your coupe seats?
Old Feb 6, 2008 | 12:44 PM
5150DS's Avatar
They probably got them from a coupe owner, but I would try a salvage yard.
Old Feb 6, 2008 | 01:34 PM
I got mine form KPierson... very cool dude. Drove to his house and picked them up.
Tim, I got all the parts at Home Depot.
Old Feb 6, 2008 | 08:09 PM
03Sg35's Avatar
Hybrid
did you figure out the wiring for the passanger side heated seats, my Driver side works but the passanger side wont heat up???
Old Feb 6, 2008 | 11:39 PM
Actually the heater worked, I guess I was too tired and irritated that night to realize that. Did you have to remove the harness plug from you sedan seat and put it on the coupe seat? It was a 4 wire plug. That controls heat and power. You may want to double check the connections.
Old Feb 7, 2008 | 12:11 AM
sc00byd00's Avatar
NY G SQUAD
hey there, anyone have a pic of the actual wiring job for reference? not too savvy with electrical and don't know which color wires go together?
Old Feb 7, 2008 | 03:09 AM
I responded to your pm as well, but the color wires match up for the most part. What part of the seat doesn't work?
Old Feb 7, 2008 | 04:47 AM
TIRE_SMOKE96's Avatar
wow I want these seats even more now
Old Feb 7, 2008 | 11:43 AM
  #30
Swivel's Avatar
Moderator
What grade a bolt did you use? I would want to make sure it was equal to or better than the OEM grade for safety, or just go with something I knew was strong, like a Grade 8. I might be concerned about the crush strength of the front plastic spacers too.
Thanks for continuing to post the details, I keep coming back here for more good info!
