G35X mods-help please
Old Mar 17, 2004 | 04:22 PM
ChicagoX's Avatar
Don't drink and Mag Race
Hi all!!
I am a new G35X owner (graphite/graphite,NAV,premium) and can't wait to start modifying the car.
Problem: I want to change the wheels to the staggered setup on the Z (the price is right for the wheels), but I am concerned with the VDC thinking the rear tires are slipping all the time. Is this a concern?
Has anyone installed a LSD unit in a G35X?
Does anyone make an exhaust system for the AWD cars?
Thanks!!
Old Mar 17, 2004 | 04:27 PM
GurgenPB's Avatar
Re: G35X mods-help please
Clint did (THX723). And it does adversely affect the handling.
Gurgen
Old Mar 17, 2004 | 04:33 PM
ChicagoX's Avatar
Sorry, Gurgen.....were you referring to the wheels or the LSD?
Thanks.
'04 G35X Graphite/graphite, NAV, wood, premium
Old Mar 17, 2004 | 06:13 PM
GurgenPB's Avatar
The wheels.
Clint has the track Z wheels on his G sedan. I have the Z VLSD.
Gurgen
Old Mar 17, 2004 | 07:14 PM
ryoken's Avatar
Things to think about.
1) No, the VDC system won't think the rear wheels are slipping. It'll think the front wheels are slipping. (The smaller wheel has to spin faster to keep up with the larger wheel.) If the sizes are very close, it may be within the system's tolerances for straight-lines, but will affect the system's overall reactions.. it make kick in sooner or later than it normally would depending on the circumstances.
2) The sedan has a natural tendency to understeer. Going with wider rear tires will increase that tendency. Unless you're doing something else to the suspension to adjust the car's handling, you may be better served with wider (but same-sized) tires on all four wheels.
Old Mar 18, 2004 | 08:33 AM
ekaz's Avatar
Speaking of wider on all four corners, which is the widest? 8.5 or 9?
Old Mar 18, 2004 | 10:23 AM
ChicagoX's Avatar
Ryoken and Gurgen-- thanks for the info.
Double-DOH! on the front vs rear wheels......
I see your point about the staggered setup magnifying the car's tendency to 'push.' Will the Stillen adjustable F+R sway bars do the job adequately? (on a non-staggered setup)
Anyone know of an exhaust system for the 'X' cars?
Any probs with the AWD and Nismo LSD?
Thanks again!
Old Mar 18, 2004 | 11:11 AM
Gsedan35's Avatar
You cannot use any avaliable sway bar on the G35X. The car use's a different front suspension (from the FX) than the other G35's and 350Z.
On the rear sway bar {EDITED, pending investigation of rear suspension}
You can send your stock oem front bar and all the mounting hardware to this company and have them bend you new custom front bar.
http://www.sanerperffab.com/products.htm
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt<P ID="edit"><FONT class="small"><EM>Edited by Gsedan35 on 03/18/04 09:31 AM.</EM></FONT></P>
Old Mar 18, 2004 | 11:41 AM
EverythingG35's Avatar
The current borla exhaust won't work on an FX, it hits the transfer case and the rear suspension. The coupe fitment is close, but not quite right... We're trying to get it all figured out currently and I'll post any updates, once we get everything figured out.
Justin @
EverythingG35.com
1.888.216.5328
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AJC128
Nov 1, 2015 11:55 AM
Claudiu
Sep 26, 2015 01:04 PM
