Clunk and rattling coming from front
Hi Guys, I have a 03 G35 sedan that recently developed a Clunk/Rattling noise when going over bumps, it's sounds worse at lower speeds. It sounds like a bag of golf ***** are rattling around the suspension area. Any ideas what it might be?
I got the same problem.Seems to be stronger on slightly uneven pavement and does not get any louder or disappears at big bumps. I checked all links/tie rod ends/strut rod bolt-all seems to be tight. Steering is OK, handling is fine.
Are you stock?
I suspect it's either strut or just spring coil insulators wore out.
Any other ideas/experiences?
Are you stock?
kinetek
Aug 3, 2015 04:25 PM
