trunk release button retrofit?
Old Mar 18, 2008 | 01:36 PM
mikehill33's Avatar
That is my trunk, and I even have the glove box switch to disable.
http://flickr.com/photos/mikehill33/...7604117977887/
I'll see if I can get it installed, especially if it is just splicing a wire.
Gonna pop the empty cap off tonight, and see what's in there.
Old Feb 23, 2021 | 09:20 AM
T Raw's Avatar
g35 sedan
Early 03 g35 trunk switch retro fitted
Originally Posted by G35Papa
Since this is in the sedan section, I'm not sure this applies to the coupe
03.0 sedans did not come with a trunk release switch/button on the interior. They did not become available till the 03.5 model. You should be able to buy the switch/button from your dealer (or PM Tony@riversideinfiniti)
I retro fitted my 03.0 sedan with one as well as an extra DC outlet.
I am trying to do this exact thing if anyone can help me out with what I need n the process please. I believe you need a switch n harness n you just wire it to the trunk lock switch in the glove box but not sure how
Old Feb 23, 2021 | 09:29 AM
T Raw's Avatar
g35 sedan
Early 03 G35 trunk switch retro fit
Originally Posted by 03Sg35
Hey Papa
Could you tell me what was involved with the retro.... I have a 03 with the doggy door but Im swapping to the 04 trunk without the latch, I would like to know if I can fit the trunk release button on mine?? Thanx
hey did you ever figure out how to do this, I’m trying to do the same thing. Switch to the 04 trunk without the switch in the handle and put a trunk switch by the dimmer n vdc switch. Please let me know
Old Feb 23, 2021 | 10:02 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I would just check the FSM on the newer model with the trunk release and see how it's wired up on paper.
EDIT: The wiring is in section BL - Body/Locks
Old Feb 23, 2021 | 12:05 PM
T Raw's Avatar
g35 sedan
I got lucky and literally just found a switch on eBay with the harness already attached with the wires cut. So I plan splicing the wire out the harness to the trunk lock switch in the glove box. Hopefully it works
Old Feb 23, 2021 | 01:28 PM
cleric670's Avatar
BANNED!!!
Ok I just checked the FSM, on the existing glove box trunk disable switch intercept/C-tap the PINK wire, run it to one side of your new trunk release switch, take the other side of the switch and run it to any chassis ground point.
When the BCM sees ground on that circuit it actuates the trunk lock mechanism.
Don't intercept the BLUE wire on the existing trunk disable button or it will no longer disable the trunk release for the new button.
Old Feb 23, 2021 | 02:48 PM
T Raw's Avatar
g35 sedan
Ok thank you for that because that’s exactly what I was about to do. Thanks for clearing that up. Waiting on the part to come should be here in a week or less and I’ll let ya know how it goes.. should be easy now
grovefromnh
Jun 29, 2011 09:58 AM
Eagle
May 4, 2009 04:11 AM
Theanimedude
May 24, 2008 07:21 PM
cnaman
Mar 6, 2007 07:09 PM
