Windshield Wipers Slapping Hard
Originally Posted by cuzz73
I told them to pack sand and I'll fix it myself. Do you know where I can get the part?
Do you have a mechanic that is reasonable and you trust? They can order it from the dealer and do the work if you dont want to.
They said they couldn't order the single part that It only comes in an assy.
My mechanic ordered the one part or arm and fixed it. The tabs were broken and he knew exactly what I was talking about when I told him what the wipers were doing. I didn't have time to fix it myself or I would have. The dealer can order that one part. If not then go elsewhere or maybe someone here can steer you in the right direction.
I'm trying to solve this problem on my 03 sedan.
Looks like I may have found the part online - #7 in their picture. $11.44
Let me know if you think that's the one!
http://www.infinitipartsonline.com/p...layCatalogid=0
Its called the assembly link arm.
They sell it seperate. It only takes 30 min to DIY. You need to get in there and see which assembly link is bad. There are 2...one on top and one on bottom. Mine was the one on the bottom.
It's most likely either part 6 or 7. I bought both at the dealer, took the car apart, replaced the needed one (it will become evident once apart), and returned the one I didn't need. Took about 45 min after R&R'ing all the plastics and re-aligning the wipers. DON'T FORGET TO RE-ALIGN THE WIPERS.
Good luck.
Good luck.
I think my wife is having a similar problem with her 2003 G35. When I was driving it before I gave it to her my wipers would sort of "stutter" if I had the setting on intermittent.
Is that what your's are doing??????
It is so annoying and I need to have it looked at.
