Anyone on their original battery?
Old Mar 27, 2008 | 04:03 AM
  #31
Andrei's Avatar
First time I heard of adding water to a battery. I have to check mine. ****ing cool.
Old Mar 27, 2008 | 10:45 AM
  #32
Wannabe6MT's Avatar
-MN G Crew-
Originally Posted by Texan1
are you sure you were not LQTM
No, it was an all out laugh
Old Mar 27, 2008 | 10:56 AM
  #33
mikeee2's Avatar
Originally Posted by G35papa
There's 6 holes and yes you have to pull the plugs all the way out. How else would you be able to see the fill line inside.
So you have to pour distilled water into all 6 holes? Also, to get the plugs out do you just twist and pull or you have to use some tools to pull it out?
Old Mar 27, 2008 | 11:04 AM
  #34
Dan in St Louis's Avatar
Originally Posted by Naveed2126
Damn, who would've thought you'd have to maintain a damn battery...
Who would've thought you DIDN'T need to? "Maintenance-free batteries" were a myth, and Infiniti wisely doesn't even pretend they are.
2004.5 Service Manual, page SC-5.
2004 Owner's Manual, page 8-16.
Old Mar 27, 2008 | 10:39 PM
  #35
Naveed2126's Avatar
I think I'm going to replace mine next week or so with a Sears Die Hard Platinum... considering I'm running a 500w amp, I think I'm gunna need to toss that OEM battery sooner than later.
Old Mar 28, 2008 | 08:55 AM
  #36
Mmagic76's Avatar
Only the holes where the water is low. Unscrew, counter clockwise and lift out by hand.
Old Mar 28, 2008 | 12:17 PM
  #37
G35Papa's Avatar
Finding tid bits of information like this is what makes this site great. I have learned so much from this board
Old Mar 29, 2008 | 01:58 AM
  #38
kenasaki's Avatar
distilled water? difference between sink and bottled?
Old Mar 29, 2008 | 02:05 AM
  #39
G35Papa's Avatar
Distilled water if filtered differently (steamed) to remove the minerals you would find in sink and regular bottled water.
Old Mar 29, 2008 | 11:08 AM
  #40
SoCalTed's Avatar
03.5 bought new and has 31k miles on it. Have run the battery down to zero a number of times at shows, it sat dormant at a shop for nearly 8 mos and gets about 30 miles a week on her.
Seems the battery should have give up with that type of treatment, but its doing fine. LOL... I never noticed that our batteries weren't maint. free. Guess I kinda assumed, since most of my previous cheaper riders were.
Gonna change it soon anyway, it's time I got a deep cycle one for shows and an lightweight optima for daily.
-T
Old Mar 31, 2008 | 05:52 PM
  #41
G35sedan03's Avatar
got a 03.5 with 53k and i'm starting to get the slow starts. i'll check the water, but most likely will get a new one. maybe an optima? i hear the fitment is an issue with our cars.
Old Mar 31, 2008 | 06:15 PM
  #42
G35Papa's Avatar
^I have a red top, fits fine but it is on the tight side. I don't know if there are any issues with the yellow top.
Just make sure you get the reverse post mounts (i.e 34r)
Old Mar 31, 2008 | 06:21 PM
  #43
lowrider's Avatar
Originally Posted by ttrank
Phoenix heat kills batteries. The oem and 2nd one lasted about 20 months each. My Optima has lasted about 18 months so far and going strong.
Originally Posted by krnn1cenamja
normal battery should last more than 100K
ttrank is correct - Southern Arizona is not kind to batteries. I change mine every 2 years - Period. When they go here, there is no warning - None.
Lou
Old Mar 31, 2008 | 10:26 PM
  #44
Noremac's Avatar
Tap water and even bottled water contains mineral salts - usually iron, calcium, and manganese. The amount of these salts varies from place to place, but these "xtra" chemicals can play havoc with battery chemistry, and reduce battery life. Always use distilled water (which has all impurities and salts removed).
Old Apr 28, 2008 | 10:52 PM
  #45
coolieman1220's Avatar
a lil over 5 years old with 40K miles on my G35,
i put the jumpers in my trunk just to be safe, they fit nicely inside the douhgnut!
i added distilled and it seems to work a lot better now!
