Difference between JDM and USDM versions
Old Mar 27, 2008 | 11:34 AM
rinox's Avatar
i'm new here and i own a JDM 250GT
to the best of my knowledge everything should be the same except for the litre size of the engine
does anyone know other differences? do all parts (performance/ exterior) that are made for the G35 sedan in US fit the JDM 2.5L model?
Old Mar 27, 2008 | 02:59 PM
ttrank's Avatar
Grocery getter
I highly doubt the 2.5L performance parts are going to fit.
Post up a pic of your engine bay and I might be able to help more.
What year is yours? Most of the exterior parts should fit.
Old Mar 27, 2008 | 09:01 PM
rinox's Avatar
mine is a 2004 model and it's the same as the first gen G in US
i will take a picture of my engine bay this weekend and post it up
from what i can tell the layout is exactly the same as the 3.5L and it would be great to know if i can use any of the intakes for my 2.5
i'm looking to put on the Z tube and JWT pop charger
Old Mar 27, 2008 | 09:03 PM
Wannabe6MT's Avatar
-MN G Crew-
Hows the performance on a 250GT?
Old Mar 27, 2008 | 09:05 PM
rinox's Avatar
it's at 225hp
Old Mar 29, 2008 | 03:17 AM
Phranknstein's Avatar
Yea post pics.i wanna see the 2.5L.
Old Mar 29, 2008 | 06:20 AM
GixxerSteve's Avatar
Hell, a 4 cylinder with 225hp -- I want the 2.5 litre option!!! Have you seen these gas prices!!??
Old Mar 29, 2008 | 10:04 AM
Carlito's Avatar
It's not a 4, it's a VQ25DD six, same as the VQ35 but smaller bore/stroke. It has direct injection as well, unlike the 35 from what I know. Here's a pic of mine:
I think most of the external engine parts will fit. I've bought a radiator off the US market for mine so far. Things like the supercharger and turbo kits won't fit because of the engine capacity (too much boost & fuel) and injectors might not fit either.
I also bought a USDM battery cover (the JDM battery is on the left side) and it needed modification to fit. I need to take a new pic of the bay to show it. Planning to get a new CF engine cover sometime. Also bought a JDM battery cover off the US market - fit like a charm.
If you look at the bottom right of the pic, the JDM 250GT has a cover on the air filter box where the G35 has a little snorkel. I pulled my cover off and the car sounds a lot better
Last edited by Carlito; Mar 29, 2008 at 04:48 PM. Reason: Change to engine model from VQ35DE (wrong) to VQ25DD
Old Mar 29, 2008 | 01:34 PM
ttrank's Avatar
Grocery getter
Looks like the intake would work. Can you take a picture with the engine cover off too? I think there is a chance the plenum spacer may fit as well.
As for the SC/Turbo kits, I bet you could use them as long as you got a re-tune. I'm not sure the plug and play engine management would be the same since your ECU may be different but something like the emanage ultimate should work.
Old Mar 29, 2008 | 01:39 PM
WILLIE BEANS's Avatar
thats why it only comes saying battery cover whene we order a brake fluid cover on our g's ..
duhh .. i never got it .lolol
Old Mar 29, 2008 | 04:02 PM
MCC73's Avatar
Originally Posted by Carlito
It's not a 4, it's a VQ25DE six, same as the VQ35 but smaller bore/stroke. It has direct injection as well, unlike the 35 from what I know. Here's a pic of mine:
Are you sure the VQ25DE is direct injection? I have the VQ30DD in my 2001 V35 Skyline and that has direct injection, apparently the "DD" signifies direct but I understood "DE" stood for Standard injection? I'd be very interested to know as then I can also fit a Z-Tube in place of the standard intake.
Cheers
Matt
Old Mar 29, 2008 | 04:44 PM
Carlito's Avatar
Sorry, I didn't realize I had put DE in my first post, it should have been DD. Must be a holdover from my R32 days (RB20DET, no DD's back then). I'll edit. My engine cover says "Neo-Di" on it, Di for direct injection.
Here's a page from the Nissan parts system showing the 25DD plenum parts.
Old Mar 29, 2008 | 07:14 PM
geesteezd's Avatar
interesting
Old Mar 29, 2008 | 09:45 PM
MCC73's Avatar
Thanks for clarifying that.
Does anyone know then if a Z Tube intake from the VQ35DE fit directly with the VQ25/30DD without modification by any chance?
Old Mar 29, 2008 | 10:24 PM
ttrank's Avatar
Grocery getter
By looks the plenum is the same. A spacer may help you like it helps us.
