0-60 MPH in 2nd gear?
Old Apr 1, 2004 | 04:49 PM
dnapoli's Avatar
This question is more so targeted to people that have done quite a few mods. I've always wanted a car that can hit 60 MPH in 2nd gear. I have a G35x so it only comes in an automatic. Does anybody out there have an automatic that hits 60 MPH in 2nd? If so, please list your mods....I would like to duplicate them if it's reasonable.
Thanks
If it's a G it's 4 me!
2004 G35x
Diamond Graphite~Graphite~Premium~Wood~Splash Guards~7 Wire Grounding Kit~Z-Tube
Old Apr 1, 2004 | 05:08 PM
zimbo's Avatar
Re: 0-60 MPH in 2nd gear?
60 mph in 2nd gear has nothing to do with how fast the car is but rather the gear ratio. If your automatic cannot hit 60 mph in 2nd gear then you can only do two things: (1) increase the rev limiter and shift manually or (2) get really tall tires
--Steve
Old Apr 1, 2004 | 06:12 PM
GurgenPB's Avatar
Mine goes to ~60 in 2nd. I do have my rev limiter raised to 7200 and even a shorter final drive ratio of 3.54 from the Z.
Gurgen
Old Apr 1, 2004 | 07:00 PM
Twylight's Avatar
You need the rev limiter raised and you can do it NP. You need to use manumatic to do it reliably after that. The rev limiter is raised after market by a Technosquare ECU mod.
I do it all the time - I shift at about 65 mph to 3rd. Redline shift basically.
Worth
2004.5 Sedan AT DG/Sport/Flaps/Premium/max tint/Bose/CAI Injen/6 wire ground kit/Custom ECU/Zaino layers=6
next mod: N2O
Old Apr 1, 2004 | 07:20 PM
ryoken's Avatar
Mine's bone stock and hits 62-63 at the rev limiter in 2nd.
Old Apr 1, 2004 | 11:51 PM
iLLG35's Avatar
NY G-Squad G Race Driver
Ryoken mine does the same exact also!! End of second rite on the redline im at 60 and get up to 62-3 before bouncing off the limiter!!
Wat'ssss Realllyyyy Goooodddd!!!!!
Old Apr 2, 2004 | 08:44 AM
dnapoli's Avatar
Maybe the G35x is geared a little differently due to the extra weight and the all wheel drive system. I bounce off the rev limiter at 58 MPH. Can anybody else with a G35x confirm that? Do the ECU mods void the warrantee? As we all know, if the car has a serious issue we can remove the bolt-ons before giving the car back to Infiniti to see what is wrong. If I was to put the ECU upgrade chip on would they be able to tell that I was using it?
Thanks for the info everybody!
2004 G35x
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
aaron3719
Sep 29, 2015 10:12 AM
beto4632
Sep 23, 2015 04:28 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
