Question for those running Z Track wheels on Sedan
Old May 18, 2008 | 07:54 PM
Tunerz_Store's Avatar
Originally Posted by Klubbheads
It won't work without rolling the fenders, that being said how much do u want for the 18" track wheels?
He don't need to roll his fenders if he continues to use 235/45/18's. I am dropped about 1.2" and have no rubbing issues what so ever.
Old May 18, 2008 | 08:37 PM
erdog's Avatar
I am tucked in the rear and running 255/40/18 and it is perfect. Can't go any wider than that for me. And I am running conservative camber settings.
Old May 18, 2008 | 11:36 PM
pics please... rear and side shots...
thanks
Old May 18, 2008 | 11:47 PM
n15m0's Avatar
This is mine with 06 Z wheels which have the same width and offsets of the Track wheels. Running 245/45 on the rears, no rubbing whatsoever.
Old May 31, 2008 | 01:35 AM
erdog's Avatar
I didn't take pics with the tire set up. But I got new tires. Falken 452, 225/45/18 in the front, 245/45/18 in the rear. So I jus went with the stock setup.
Anyone know if there are infiniti center caps that fit the track wheels? The center caps off my stock 17's are too small, by about 5 mm.
Old May 31, 2008 | 03:33 AM
I used center caps off non sport 17" sedan wheels. They fit fine.
Old May 31, 2008 | 03:48 AM
G SEDAN's Avatar
you can dremel out the nissan emblem easy, just the 2 melted tabs behind the center caps. They will pop off easy after you grind down the tabs. Do the same to your infiniti one and re-glue it and you have yourself a perfectly fitted Center cap
Old May 31, 2008 | 08:41 PM
erdog's Avatar
Is it safe to try to pop center caps off without taking the wheels off?
Old May 31, 2008 | 11:18 PM
I wouldn't.
Old May 31, 2008 | 11:56 PM
G SEDAN's Avatar
^ +1.......
no matter what kind of flat head you're using, you're bound to damage the plastic edge when you pry it...
take time to do it right
Jusseth
Sep 13, 2020 12:25 PM
rezendvous420
May 31, 2020 01:26 PM
joel extreme
SOCAL Meetings & Events
Jul 23, 2015 04:13 AM
mushu
Jul 15, 2015 03:55 PM
