SEDAN BILLET GRILLE **PIX**
Old May 5, 2004 | 11:58 PM
  #76
gdupg35's Avatar
Re: More pics....
My wheels are Binno 20x8 (42mm offset).
As far as the install goes, an 8 year old could do it. There are four plastic mounting tabs on the top of the factory grille. They are easily pryed off.
The new grille comes with two mounting bolts, and lock washers. The instructions advised using two of the original plastic tabs, but I managed to use all four just as a precautionary measure.
It's really that easy.
Old May 6, 2004 | 01:30 AM
  #77
GeeSpot's Avatar
Re: More pics....
That is a nice look for your G. Thanks for the pics!
Old May 6, 2004 | 01:44 AM
  #78
gdupg35's Avatar
Re: More pics....
I definitely like it. Thanks for the compliments. I think it looks really "clean".
Old May 6, 2004 | 02:39 AM
  #79
GeeSpot's Avatar
Re: More pics....
It does have a "clean" look, Gdup. Later, if I still have my G and want a change, I may well sport a billet grill for awhile. Not too expensive, and you made it sound easy to do. I was wondering what it would look like with just the top, so your pics are a big help - Thanks again.
Old May 6, 2004 | 02:55 AM
  #80
gdupg35's Avatar
Re: More pics....
thanks again... It actually does look way better in person. For some reason the billet freaks out my digital camera. I can actually see movement in the image - a sort of "wavering" of the grille slats.
Old May 6, 2004 | 11:24 AM
  #81
jasijay's Avatar
Re: More pics....
Hey gdupg35, Looks AWESOME!! you said in your post that you went with only the upper part, does that mean there is a Billet for the bottom part (Non-Areo) for the Sedan?
03 Sedan, White on Black. Aero kit, Clear Corners, Stillen Exhust, Grounding kIT & High Flow box, .Z-tube, 18'' XS Style, Eibach Pro-Kit.
Old May 6, 2004 | 11:55 AM
  #82
SaikoSurfer's Avatar
Anodized Grille...
Ok, just ordered mine with Adam from Stillen (a really cool guy!). I'm supposed to be getting it on Monday or so. As soon as I get it, I'm going to send it off for anodizing, probably a gunmetal like color, then figure out a way to mount an emblem on. When it's all in place, I'll put up some pictures.
Thank you everyone for all your help!
Old May 6, 2004 | 02:31 PM
  #83
jaerian's Avatar
Re: More pics....
Yeah, they make the bottom half also, I don't know where Gdupg35 got his brille from, but precision designs, pototype thyped the top and bottom of my car for a non aero sedan, if the picture does not show up, click on my name and you can see the pictures of them.
'04 G35 Sedan 6 MT DG/DG
'02 BMW M5 13.3 @ 107 (wifey)
'03 Cadillac Escalade
Old May 6, 2004 | 07:08 PM
  #84
gdupg35's Avatar
Re: More pics....
I have the T-Rex brand grille. Stillen is the only one who technically has them available right now. T-Rex does NOT make the lower pieces for the non-aero sedan (at least as of now). It cost me $195.00.
Old Jun 12, 2004 | 06:46 PM
  #85
achee's Avatar
Re: More pics....
Hey guys, I just bought this grille for my sedan and the installation is not going well. I have no idea how to install this sucker. The top grille has two tabs that connect to the car on top but nothing on the bottom. I don't know how to lower grille installs. Anyone have directions?
Andrew
Old Jun 12, 2004 | 09:06 PM
  #86
gdupg35's Avatar
Re: More pics....
It should be super simple. It took me about 5 minutes for the top piece. (I don't have the lowers so I can 't help you there) Can you take a pic and post it here so I can see what you've got?
-"Nobody makes me bleed my own blood, nobody!
Old Jun 13, 2004 | 01:10 AM
  #87
achee's Avatar
Re: More pics....
The top piece went in real easy. The lower pieces were a mystery. There are two screw holes on the lower grille but there are no corresponding screw mount points. The aero lower grille has a black plastic piece that looks like the grille might be screwed into but that's not right either. Any ideas folks?
Andrew
Old Jun 16, 2004 | 08:32 AM
  #88
jasijay's Avatar
Re: More pics....
Achee: I'm with you, I just (finaly after 7 weeks) got the Non-Areo grille. The top piece went on fairly easy but the bottoms have me scratching my head! they give you long bolts that go no where and the side holes int he grill piece really don't line up on th esides. Very perplexing. If any one has figured out how to install (As they sent no instructions for the lower pieces) please post. Thanx
03 Sedan,Clear Corners, Blinker Mirrors, Stillen: HFAB, GK, Exhaust, Z-Tube, Eibach Pro Kit, 18'' XS Style 420's
Old Jun 16, 2004 | 11:12 AM
  #89
achee's Avatar
Re: More pics....
I called T-Rex Billet and spoke to a guy named Mark. He says that he thinks that they sent the wrong mounting hardware. There should be more of a hook shaped piece and a longer bolt to hook behind the black plastic fin. Anyways, he's sending me the parts right now and I'll let yall know if I can get it on.
As a work around, if you can go to a hardware store and find a 3-16 thread bolt in black (cause a silver bolt head would show on the grille) that's about 4-5 inches long and some kind of hook bracket at the end, you can probably fix it yourself.
Andrew
Old Jun 16, 2004 | 03:30 PM
  #90
jasijay's Avatar
Re: More pics....
Andrew...Thanx for the sugestion. I called Presion Design and after they made me feel stupid, I got it on no problem...Take a look....
