Removing Hood Support
Old May 13, 2008 | 10:38 AM
Smokey6's Avatar
Just installed NRG hood struts yesterday, and was planning on taking out the hood support. Aside from noting that some plastic paneling will have to be removed to get at the nut holding it on, I haven't really assessed what's involved to do the job.
Any suggestions with this seemingly easy job?
Old May 13, 2008 | 11:46 AM
G35Papa's Avatar
Just leave it on That's what I did when I installed my NRGs
Old May 13, 2008 | 11:58 AM
Boston's Avatar
There is no nut to remove. The OEM hood support rod is held in place with the rubber grommet that is visible. A good steady pull will remove it. When and if you want to replace it, push the rubber grommet back into the existing hole. Shouldn't take more than 10 seconds!
Old May 13, 2008 | 04:44 PM
Smokey6's Avatar
Thanks.
I actually figured it out before this got posted, but good info none-the-less. Looks a little cleaner with the bar out of the way.
Old May 13, 2008 | 05:38 PM
Boston's Avatar
^ I agree, I removed mine as well.
Old Oct 6, 2019 | 10:24 AM
PrimeXample's Avatar
They are pretty easy to take off, but anyone have tips to reinstall the hood prop? I replaced the radiator support and there must be some trick because I can't get it to seat the PROPer way
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
hrdwirk1
Oct 2, 2015 06:34 PM
dcsbh1
Oct 1, 2015 03:15 PM
