Alarm Horn is off ,i need help!
Old Oct 9, 2019 | 03:02 PM
n3llyfl0w's Avatar
nice and steady
The issue is the following , i get close to it and lock and unlock (it kind of makes a noise but it cant ) (by the way the horn works perfectly)
I did the lock and unlock (pressing at the same time for second and switch it to one time flash of the hazards and still same thing ,nothing
what could it be for me to fix this on a g35x 2006 sedan- got it to work for the panic button , but the honk on locking is very low
Old Oct 9, 2019 | 04:25 PM
Jonny Rivera's Avatar
2005 Light Blue infinit G35 sedan RWD
05 g35 Sedan Cranks but won’t start
Hey Guys I need your help! I have a 05 G35 sedan RWD. Coming out of work one day my car wouldn’t start. If cranks but would not get any spark I checked crank sensors, fuel pump, starter, fuses, at this point I am lost and just really need to get my car started does anyone have a clue what it could be ? My key has piece of the black rubber broken off could that have anything to do with the chip transponder causing it to not start? Help pleasee
Old Oct 9, 2019 | 04:28 PM
n3llyfl0w's Avatar
nice and steady
dude make a new post , dont post on mine my g ,not unless you have an answer for mine
Old Oct 9, 2019 | 04:33 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
@Jonny Rivera If your key has the transponder broken off or if the transponder is just not working then you will have a solid red NATS indicator light on the left side of the dash when cranking. NATS prevents fuel/spark. Also, you should create a new thread instead of hijacking someone elses thread.
@n3llyfl0w Mine does the same thing when I lock the vehicle, chip is very quiet. I've suspected this is an early sign of the horn relay starting to wear since it has a mechanically moving part actuated by an electromagnet (typical relay) and the BCM horn pulse length is so short when it chirps the horn on lock that after 15 years of age on the relay the moving parts just don't move as quickly and thus the signal getting sent to the horn is much shorter and barely enough to even make noise.
Old Oct 9, 2019 | 04:36 PM
cleric670's Avatar
BANNED!!!
Also, there is usually a note adjustment screw on horns, I haven't looked to see if the G35 has them but it adjusts tension on the internal part the diaphragm that creates the noise and it's possible the diaphragm doesn't move as quickly due to the polymers aging but I don't think it's the actual culprit because my horn sounds just fine when you actually use it.
Old Oct 9, 2019 | 04:38 PM
n3llyfl0w's Avatar
nice and steady
thank you my man ill look in to the relay and the horn thingy if i could change the pitch
Elite130
V36 Interior, Exterior & Lighting
Oct 15, 2011 12:24 AM
thebayg35
Nov 19, 2010 07:58 PM
Choleaoum
May 21, 2010 02:02 AM
CityGtrea5
Aug 22, 2007 12:52 PM
ChromiumBlue7
Apr 30, 2007 09:46 AM
