GT Spec Lower Front Bolts
Old May 14, 2008 | 05:12 PM
marty315's Avatar
Hey guys,
I'm working on trying to install the GT Spec Lower Front Strut bars and I can't get the bolts loose. Anyone know any tricks? I've got the deep socket on it, I've got the breaker bar working. I've tried spraying it with PB Blaster... I can't get either side loose. Help!!?
Old May 14, 2008 | 06:11 PM
OCG35's Avatar
strut bar?... they have a front brace, but I wasn’t aware it mounted to the struts?... I was hoping for the 4 point mid brace... anyway good luck, let us know how it feels driving once you get it installed...
Old May 14, 2008 | 06:32 PM
marty315's Avatar
Lower Tie...
Sorry, not the strut bar (I do believe they make one) but the lower front tie bar. It's underneath the car just behind the new Stillen sway I just installed. All of those nuts were tough to loosen but came loose after awhile. I can't get these other two out for the life of me. I've already taken the car off the ramps and I guess I'll just wait until I get the other two braces and have them installed all at once.
Old May 14, 2008 | 10:20 PM
03Sg35's Avatar
heated it up with propane
Old May 14, 2008 | 10:23 PM
marty315's Avatar
Is that safe?
I've got access to a small propane torch from my working at a restaurant where we do flambeed creme brulee. But that makes me nervous to do that under the engine especially. What exactly would you do?
Old May 14, 2008 | 11:19 PM
OCG35's Avatar
I dont think I'd be lighting a fire under the car ... but thats just me...
Old May 14, 2008 | 11:47 PM
marty315's Avatar
That was my original feeling about it as well. I think I may just wait to get another GT Spec bar or two and then get them all installed professionally by a shop. But definitely glad to have the sway bars in. Didn't really get time to try them out though. Looking forward to the drive tomorrow.
Old May 15, 2008 | 12:14 AM
OCG35's Avatar
actually it's probably better this way... you can test the sway bars then see how much (if any) difference the tie-braces make...
I have Stillen sway bars and would be interesting in hearing your before and after impressions of the GT Spec with sways...
Old May 15, 2008 | 01:00 AM
marty315's Avatar
True...I guess installing them at the same time wouldn't have done much for me as far as detecting which one made the most difference.
Old May 15, 2008 | 04:13 AM
03Sg35's Avatar
Unless your leaking fuel all over your suspension parts i dont see what could catch fire?? Just pay attention to what your heating and it will come loose. Keep the flame small and hot, no biggie really. But if you dont feel confident then pay someone $67 an hr do it.
Old May 17, 2008 | 11:34 PM
marty315's Avatar
What will this do, heating up the bolts? Anyone else think this might be a good idea?
Old May 18, 2008 | 01:16 AM
Lucky-G's Avatar
metal, like most everything else, expands when it gets hot. You get that bolt hot enough and it'll damn near fall out lol. He's not steering you wrongly, most likely that's what a shop will do if they can't get it off. Using a torch to get stuck bolts off is cake, get the bolt hot enough to turn red-ish, then crank it off. Easy as pie.
Old May 18, 2008 | 11:52 AM
ttrank's Avatar
Grocery getter
I've had to heat some bolts to get them off before. I have a small butane torch that I use.
Old May 18, 2008 | 01:21 PM
Lucky-G's Avatar
If tim does it, that means it's right
Old May 18, 2008 | 01:40 PM
QuadCam's Avatar
2 words: Impact Gun!
