03 Sedan AT Fluid Check ?
Old Mar 23, 2010 | 11:46 PM
Tollboothwilley's Avatar
Ya, but its stupid that Infiniti would not include a dipstick at all... which leads me to the fact that there could be issues.
Old Mar 23, 2010 | 11:49 PM
NFSP G35's Avatar
? = 2B || !2B
Yes, that is true, but I can see their logic behind not doing so.
It's to make people take it to the dealer for service.
I can't find any logic to build it differently, especially when considering the fact that it's the same transmission as the Z and the same dipstick works in the same way.
I think you're worrying about it too much man.
Old Mar 24, 2010 | 12:08 AM
LOL.
Well, the only reason I am worried, to be honest, is that the parts manager told me it was a different charge pipe. Because of that, I don't know what to expect. I'd assume its not a problem but I wanted to make sure.
Old Mar 24, 2010 | 12:11 AM
NFSP G35's Avatar
? = 2B || !2B
^Different from the Z or different from the newer sedans?
Old Mar 24, 2010 | 08:23 AM
geew1z's Avatar
"special service tool" lmao! They probably got sued and had to start supplying everyone with the special tool
Old Mar 24, 2010 | 09:45 AM
VQEric's Avatar
I bought one a couple of months ago for my 2003.0 and have been keeping it in with no problems. Had it out several times to check fluid during 2 drain and fills, and the end wasn't chewed off, haha.
Old Mar 24, 2010 | 10:53 AM
Dan in St Louis's Avatar
Mercedes quit providing owners with an easy way to check transmission fluid level. The reason given was that owners were introducing contamination, including small lint particles from the rags they used to wipe the dipstick, and number of transmission problems from that exceeded the number due to low fluid.
Old Mar 24, 2010 | 01:53 PM
OCG35's Avatar
^^^ this is exactly why I think Nissan initially made in not serviceable for owner... plus the issue of J-Matic only... I always figured they didn't trust owner not to put wrong fluid in.
Athen, just leave it in, I'm sure it is fine... as for the difference in "charge pipe", I'm going to look up the early model FSM (if I can find one) and compare what I can to the one I have...
Old Mar 24, 2010 | 02:18 PM
phisig's Avatar
What is a Charge Pipe? I thought that was the pipe coming off an intercooler?
Old Mar 24, 2010 | 02:25 PM
OCG35's Avatar
both references in fsm are virtually identical (instructions and diagram)... so I can't believe the early model will be any different from when they started including the dip stick...
pdf references attached
File Type: pdf
File Type: pdf
Old Apr 2, 2010 | 06:24 PM
phisig's Avatar
Just ordered 9 quarts and the dipstick. I think I am going to do two drain and fills and clean everything out.
Old Apr 14, 2010 | 07:03 PM
phisig's Avatar
I just checked my fluid with the new dipstick (part 31086cd100), it is reading high. Am I correct in thinking the fluid should be in the middle of the striped section on the dipstick right when hot? I assume it should be between the lower two notches for a cold reading?
I am changing the fluid tomorrow morning, I need about 4 quarts to refill???
Old Apr 15, 2010 | 11:22 AM
phisig's Avatar
I put 3 quarts in, ran it around the block, trying to heat up the fluid for a clear reading. Do I want to check the fluid in neutral or park?
Old Apr 15, 2010 | 01:45 PM
phisig's Avatar
^ If anyone had some feedback for me that would be great.
I put in 3.5 quarts and it seems to be reading inbetween the two notches when HOT.
Old Apr 15, 2010 | 02:16 PM
  #30
SLVR JDM's Avatar
I wish I could help out, but I've never done the service myself. I'm going to do it in the next few weeks though once I have a better understanding of the procedure.
