Help! No Power - Dash Lights On, ABS VDC and SLIP Blink
Old Jun 10, 2008 | 04:50 PM
G35 4Me's Avatar
Started up my 03 Sedan today and all the dash lights ame on and stayed on...ABS VDC and SLIP started to blink....I couldnt get any pull out of the car...pressing the gas only increased the rpm by maybe 2 or 3 hundred...no accelleration at all. Its a rainy day and im hoping is some sensor or something....Drove it last on Sunday and it was fine. ANY IDEAS??
Old Jun 11, 2008 | 01:23 PM
G35 4Me's Avatar
HELP!! My '03
Anyone with an idea of what this could be?? I looked at other posts but could not find any with both circumstances. dash lights and no acceleration/power
Old Jun 11, 2008 | 06:55 PM
Christian's Avatar
Bump for a thread I just moved.
Old Jun 11, 2008 | 07:45 PM
ttrank's Avatar
Grocery getter
I had that problem when I had two different diameter wheels on my car and it went into limp mode.
I have heard of the throttle body and/or mass air flow sensor causing issues like this.
Old Jun 15, 2008 | 05:51 AM
johnsonhuang's Avatar
i am currently having the same problem. will be taking it to a shop on tuesday to get it checked. the guy said it could be a improper ground...
Old Jun 18, 2008 | 04:37 PM
G35 4Me's Avatar
Let me know how that went...took it to the shop and they said its the alternator...
Old Jun 27, 2008 | 04:10 PM
i took it in today and they said i was low on brake fluid which caused the brake light to come on and pads werent touching the rotors correctly. topped it off with some fluid and everything went away.
Old Jun 27, 2008 | 09:30 PM
Kazaam's Avatar
Either low brake fluid, or a bad sensor in your throttle body, I've had both problems in the past 4 months.
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Luisgalvan33
Jul 19, 2018 08:16 PM
wonderizm
Sep 24, 2015 03:09 AM
