How do you turn off traction control?
Old Jun 18, 2008 | 05:11 PM
xECKSx58's Avatar
how do u turn off the tc in a 2004 g35x sedan?
Old Jun 18, 2008 | 05:18 PM
LAG35NBLACK's Avatar
There is a button to the left of the steering wheel. Just press it and it should turn it off but every time you turn off the car it turns back on.
Old Jun 18, 2008 | 08:07 PM
xECKSx58's Avatar
the vdc off button?
Old Jun 18, 2008 | 08:19 PM
Foques's Avatar
yep.
VDC = Vehicle Dynamics Control
Old Jun 18, 2008 | 09:49 PM
BJD275's Avatar
Quick question while were on subject,
Is VDC only a traction control system or does it also cut power when needed and apply brakes when needed?
Old Jun 18, 2008 | 10:30 PM
maciejk's Avatar
cutting power when needed and applying brakes when needed, isn't that how traction control is achieved?
Old Jun 19, 2008 | 03:57 AM
gtbigup01's Avatar
It cuts power when needed, like in low traction situations or skid out situations. Doesn't apply brakes. If you're anywhere that snows lightly or heavy, find an empty parking lot with a little snow and play with it on and off and you'll get a better understanding for what it does. Wet areas are good too, but I find snow the best I'm in TX and don't see that often, but when i do you better believe I'm in it playing around, with VDC OFF of course
Old Jun 19, 2008 | 04:09 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
correction... VDC DOES apply the brakes in extreme situations. I used to go through canyons at anywhere from 60-100mph and when i forgot to turn VDC off, it would apply the rear brakes when the car felt it was loosing traction (measured by wheel spin) With VDC off it will not apply the brakes or cut power.
-GP-
Old Jun 19, 2008 | 10:52 AM
MidnightG35X's Avatar
Traction control is cutting power to the wheels, stability control is generally traction control plus the ability to apply the brakes. Traction control helps you get going, stability control tries to keep you in control once you are going.
VDC (Vehicle Dynamic Control) = Stability Control
Old Jun 19, 2008 | 12:26 PM
Jedakiah's Avatar
Turn off permanently
Has anyone devised a way to make it remember it's off after the car is restarted? Or is there another way to turn it off?
Old Jun 19, 2008 | 12:28 PM
Foques's Avatar
i thought it is a switch that has two positions.. I may be wrong, though.
Old Jun 19, 2008 | 12:31 PM
Jedakiah's Avatar
I have an 03. Maybe they fixed it later?
Old Jun 19, 2008 | 12:45 PM
jimmyc13's Avatar
Yes, I believe KP Technologies has a product that does this. If you turn the VDC off, it will stay off, regardless of how often you leave your car/restart it, etc.
Old Jun 19, 2008 | 03:01 PM
BJD275's Avatar
I wish we didn't have open differentials. Because then you could turn it off and not just slide right but also left.
And thanks for clearing that up for me guys.
Old Jun 19, 2008 | 03:30 PM
Jedakiah's Avatar
Hey thanks. I just bought one.
