Sedan Performance Suspension Question
Old Jul 5, 2008 | 10:15 AM
FlyingLumpia's Avatar
They dont make Illuminas for the G. That would be the d-specs
Old Jul 7, 2008 | 01:09 AM
GF-4D-G35's Avatar
I have the revised z shocks and springs on mine. I have been really happy with the ride and spent less than $200 for them. My biggest complaint was the bouncyness of the rear but the higher spring rates of the z springs seems to have fixed that. I had the sport suspension so just the rears really changed but that was enough to make me happy.
Old Jul 7, 2008 | 09:59 AM
SoCalTed's Avatar
Mike:
Tough out the setup you have right now until you have the extra $500+ to get basics or flexs. I've run Eibach prokits and Eibach Sportlines on OEM Sport suspension... when I go the prokits I liked the look but it as you know is quite jarring on bumps / RR tracks. Sportlines were no better, but loved the lower look.
When I got the Flex coilovers I was like, "FRACK!!! I shoulda just done this in the first place!"
Save the extra couple of bills, sell your springs. Let me know if you are interested and I'll get you a hook up.
-T
Old Jul 7, 2008 | 10:10 AM
dofu's Avatar
20 Year Member
Tanabe Sustec Pro 5 or 7 if you have the money. When I bought my last suspension, none of these were available yet...
Old Jul 7, 2008 | 11:21 AM
OCG35's Avatar
Originally Posted by SoCalTed
Mike:
-T
Thanks Ted - thats the kind of info I need... If better shocks wont help with the Eibachs, I guess I'll have to spend more $$$$
I'm still on OEM non-sport shocks, so it would be time for new anyway... I was thinking decent struts would help... but since you've gone the exact same route already I guess I'll reconsider my plan... I'll give you a call about that "hook up" - thanks
Old Jul 7, 2008 | 01:25 PM
apintojr's Avatar
Originally Posted by Kazaam35x
Yeah, I think it was SEDDON or APINTOJR who told me that it would run me $800/$900 for the set, then pay an extra $1000 or so to get the front pair customized to fit my X sedan. That's crazy, don't know what other options I have, that's why I'm glad the OP started this thread cuz I may find new ideas or answers from others.
well i paid about 400-450 for the back koni yellows, then i bought a set of front stock shocks for 150 for both. then after koni was done with them, i paid almost 900+shipping to get them back reworked.
sucks for me now though, one of my custom koni's started to leak fluid when i was putting in my H&R's =( so now i'm back on stock shocks for the fronts and debating to send my koni's back to get re-worked or wait if the coilovers ever come out.
Old Jul 7, 2008 | 01:53 PM
10nara's Avatar
On my 04 6mt, I'm running eibach pro-kits with Tokico D-specs and I like them. Ride quality is of course stiffer than stock but not like bmw 3 series sport package.
Old Jul 7, 2008 | 02:01 PM
Jeff92se's Avatar
Red Card Crew
Originally Posted by OCG35
Site mods; please keep here, as it is 03-06 sedan specific… I researched in suspension forum and there are too many options that aren’t specific to my needs.
So sedan guys – I’m trying to slow down on the expense of my addiction (need to start doing more engine stuff soon, so want to be budget conscious for a change)…
I’m currently on Eibach Pros with stock non-sport shocks… I realize coilovers is the best choice (but not the most economical)… So I’m considering performance oriented struts… Tokico D-Spec? KYB? Other?… Good shocks to use with the Eibachs... I’m looking for good cornering handling with reasonable ride comfort…
Vlad? Tim? What do you guys suggest?… What are you on and have had and would you recommend?… And any others that have performance suspension.
I really want to button up all this ancillary stuff and get back to HP & TRQ!
I think you have to define what you want out of your suspension. Track or street. Willing to give up ride quality for performance? Need to raise/lower the car often? etc...
The stock non-sport shocks wouldn't even be adequate for the oem sport/coupe/Z springs much less a stiffer spring like the eibach?
I grab a set of D-specs used and see how you like them. I'm on Konis(Z/coupe springs) and are very happy with them. Big difference in shock stiffness inbetween the Konis (even at their softer settings) then the oem non-sports.
I don't plan on raising/lowering the car, I don't want it any lower and I don't want the hassle/cost of camber correction. I'm also happy with the very moderate increase in spring stiffness these provide vs non-sport oem springs. I also won't track the car either. But I'd still have a problem if I did because I'm not sure I'd be willing to daily drive with a spring stiffness a tracked car requires. Regardless of how soft I could dial back the shocks.
Old Jul 7, 2008 | 02:27 PM
OCG35's Avatar
Jeff, I've been on Eibach with non sport shocks for nearly 2 years... I don’t know where you get the idea that "The stock non-sport shocks wouldn't even be adequate for the oem sport/coupe/Z springs much less a stiffer spring like the eibach?"... Eibach designed the Pro springs from a non-sport sedan
Anyway - I have a completely different setup, desire and need that your car... thanks anyway.
Old Jul 7, 2008 | 02:29 PM
SDGenius's Avatar
okay, i'll add my 2cents... i've been dropped on H&R's for almost a yr now and it's not too bad w/the OEM non-sport shocks & struts(speed bumps are quite the ordeal though). with that being said, imma upgrade to the Tokico HP shocks & struts for the 350Z. i wanted the Koni's for the longest time BUT i don't really need adjustable one's.
Old Jul 7, 2008 | 02:38 PM
Jeff92se's Avatar
Red Card Crew
Oh that's right, I guess the Eibachs were springed pretty conservatively.
Okay, good luck with whatever setup you decide on. I still suggest the Tokicos like the other gentleman suggested. Not sure how the (apparently) softer Eibachs will pair with any track intentions you might have.
Old Jul 7, 2008 | 02:45 PM
Swivel's Avatar
Moderator
Jeff, now that you've had the Z/C springs on for a while, how's your tire wear? Any issues?
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
CJay
Aug 1, 2015 03:57 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
