What does your temperature climb to in HOt Weather?
Old Jul 7, 2008 | 10:46 PM
infinitialex's Avatar
My climbed to 223 degrees today as i was hot rodding it a bit in humid 91 degree weather.
Is this a cause for concern?
Old Jul 8, 2008 | 11:45 AM
Naveed2126's Avatar
Are you talking about the temp. display in the dash? Cuz mine is always off, it shows a few degrees more than it really is. I assume it's due to the heat getting trapped in where the thermostat is for this unit.
Old Jul 8, 2008 | 11:56 AM
SoCalTed's Avatar
There's an easy test for this... look in the mirror.
If you see this:
Then you're probably running a little warm.
Seriosuly though, you talking your dash temp gauge, or do you have an external gauge for oil, trans or water temps?
Old Jul 8, 2008 | 12:13 PM
how would I be able to tell anything from the dash temperature?
Im reading mine from obd2 port
Old Jul 8, 2008 | 12:40 PM
Naveed2126's Avatar
So we're suppose to guess that you're using an OBD II scanner and you're not talking about the obvious temp. display in the dash... hmmm
Old Jul 8, 2008 | 01:03 PM
Klubbheads's Avatar
mine is usually spot on after 15 minutes of driving.
Old Jul 8, 2008 | 01:15 PM
Yea, spot on means anywhere between 150 and 230 degrees
dash gauge is garbage on accuracy
Old Jul 8, 2008 | 01:26 PM
Klubbheads's Avatar
no, spot on means that it shows the same temp that is posted on buildings on the streets that u drive on.
Old Jul 8, 2008 | 01:48 PM
Coastal's Avatar
I believe he's referring to engine (coolant) temperature guys.
It going to be hard for any of us without OBDII scanners to say though....
Mine runs to the "upper-middle" part of the crappy guage. :P
Old Jul 8, 2008 | 01:59 PM
Klubbheads's Avatar
damn, now i feel stupid.
Old Jul 8, 2008 | 02:54 PM
sloppymax's Avatar
the z, g coupe thermostat is rated somewhere between 10-12 degrees cooler than the 03-06 sedan one. nice small upgrade for 15 bucks with the gasket from the dealer.
Old Jul 8, 2008 | 03:10 PM
SoCalTed's Avatar
The thermostat does not control the temp of the car, it only controls when it allows coolant/fluids to go through the radiator to be cooled, allowing your car to warm up. By the time your coolant reaches 200 to 218 F your t-stat is already wide open.
Here's one of those comparison charts for you to plot out where you want your temps to be... Also includes a tranny chart. I have both oil and trans secondary coolers on my sedan.
-T
Old Jul 8, 2008 | 06:45 PM
kevink's Avatar
Once at operating temperature, mine always reads right in the middle of the gauge, winter or summer. What temperature that maps to, I don't know.
Old Jul 8, 2008 | 10:21 PM
sloppymax's Avatar
-T
I did not intend to sound as it changed the temp of the car. I should have said with the lower z/g coupe t-stat that my coolant temps while driving have dropped an average of around 8 degrees in my environmental conditions. (verified with autoenginuity) Nothing monumental but I was not speaking of allowing the car to run then sit at idle or remain at idle until the t-stat is wide open.
Old Jul 9, 2008 | 01:27 AM
Im surprised not many people with G's have obd2 scanners gadgeds,
I got a few myself, I have an obd2 scanner unit that plugs into the laptop and has tons of features, and just recently I purchased Nitrod , very cool device , works as a gtech and has all the scanning capability, is small, looks awesome and is always in the car displaying OBD2 info...
You guys got to get some...
