What does your temperature climb to in HOt Weather?
Well, in the first post you answered your own question.
1) You were hot rodding
2) The temp out side was hot
I guess my question is what do you expect? 223 degrees is not uncommon under extreme driving/conditions. As long as the car wasn't overheating, there should be no issue.
If you want to lower coolant temp slightly, consider getting a 300ZXTT radiator cap.
Originally Posted by infinitialex
Ok I always thought a cap was just a cap, what would the cap have to do with Lower coolant temps????
Higher pressures being more efficient, but harder on seals, hoses, etc.
The 300TT cap is 17psi (i think) where the stock is 13psi.
The nismo cap is 18 or 19psi.
I havent' tried them, but it sounds like a good idea if you're running the car hard. eg. track days, mountain runs, etc.
Originally Posted by Coastal
AFAIK, the rad cap regulates the maximum pressure of the coolant.
Learned Hand
Oct 1, 2015 09:02 AM
