Cruise control not working
Old Jul 10, 2008 | 01:37 AM
tflilal's Avatar
Ok so I tried using my cruise control like 3 times, and out of those 3 times, NONE of it worked! I turn it on and let go if the accelerator. Instead of staying the speed im at, the car deaccelerate faster than usual.. is something wrong or am i not using the cruise control right?
Old Jul 10, 2008 | 02:28 AM
maliy06's Avatar
How are you using it?
Old Jul 10, 2008 | 02:55 AM
tflilal's Avatar
i just press set/coast or something like that
Old Jul 10, 2008 | 03:20 AM
Alan's Avatar
well you need to turn it on first
Old Jul 10, 2008 | 03:50 AM
Joe_Camel's Avatar
turn it on and you'll see a green 'cruise' indicator in the gauge cluster, then hit set/decel/coast and you'll see another green 'set' indicator. BAM you're cruisin'.
Old Jul 10, 2008 | 04:06 AM
dvsmeth0dz's Avatar
Im sure you need to hit the set/decel/coast button like Joe_Camel stated, before you release the accelerator then it should hold your speed. Oh and cruise control will turn off if you shift gears or apply the brakes.
Old Oct 12, 2008 | 02:20 PM
baybayskidz's Avatar
I am having the same prob. Very annoying! Anyone know of the fix? Thanks....
Old Oct 13, 2008 | 10:07 PM
Joe_Camel's Avatar
You have to turn it on first. It automatically turns off every time your switch off the ignition, so you have to turn it on every time you want to use it, then hit the 'set' button.
Old Oct 14, 2008 | 01:26 AM
6MTFTW's Avatar
Also, if you have a 6MT, make sure your clutch pedal is fully disengaged. My clutch pedal use to stick 1/2 way down (just enough to where it wouldn't slip). That wouldn't let my cruise control work.
Old Oct 14, 2008 | 10:10 AM
I got my curise to work. Turns our my clutch pedal wasn't fully disengaging. There is a button your pedal must push down when it is in the home position. I had to adjust that so it would make contact with my pedal when released. You can adjust this by turning the 13 or 14mm nut that is holding that button in place. Make your adjustment, and you are good to go...
arora_g35
Apr 16, 2026 02:52 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
WillisFL
Dec 29, 2016 08:56 AM
kd03g99
Jul 30, 2015 11:24 AM
CrazyLogic219
SouthEast
Jul 15, 2015 02:35 PM
