a couple issues!!
Old Jul 16, 2008 | 01:14 AM
jayflyxx's Avatar
a couple issues!!
sup guys, i have a 05 G35x with 68k (yeah i drive alot) my back windows make creaky noises. i know its the bolts from searching but is it hard for me to fix myself (no experience)? my local infiniti dealer wants to charge $200+ to fix b/c im out of warranty. and my second issue is when i go from park to reverse or park to drive and start moving i hear a click from the rear wheels.. just a quick click.. anyone know wut it is?? thanks in advance.
Old Jul 16, 2008 | 02:23 AM
bbug's Avatar
I don't think I have heard of a solid solution for the creaky noise from the rear. I have tried tightening some bolts behind the seats but that did nothing. I've also read of some dealers actually cutting and modifying that rear brace. Search "rear window cracking" and you should see several posts on this subject.
Old Jul 16, 2008 | 08:49 AM
lexusk8's Avatar
There is a DIY fix for the rear axle clicking problem (common for the 2003-05 G35):
https://g35driver.com/forums/engine-drivetrain-forced-induction-diy/129450-clicking-axle-fixed.html
The TSB link is dead in the above URL. Here's the link for that TSB:
http://x.infinitihelp.com/forum/loca...p=10&keyid=135
Old Jul 16, 2008 | 09:11 AM
esfoad's Avatar
I fixed the creaking windows myself. I pul;led down the weather stripping at the top and put in a piece of additional weather stripping I bought at Lowes. Then I replaced the factory weather stripping. This makes the windows seal tighter and stops the creaking. Much less than $200! Hope it works for you. BTW, my 05X has just passed 73K miles! I drive alot too.
Old Jul 17, 2008 | 03:33 PM
mediumred91lx's Avatar
The windows are a common problem, we replace window regulators to fix them normally, as for the axle, its not hard, pull the rear axle shafts out and put some moly grease on the ends where the make contact with the wheel bearing, fixed!
Old Jul 17, 2008 | 11:23 PM
maciejk's Avatar
its a 20 min job if u have to grind those 2 bolts yourself
chinee
Jun 10, 2024 07:48 PM
rezendvous420
May 31, 2020 01:26 PM
Frostbite91
Aug 20, 2015 07:20 PM
itschuckster
Jul 25, 2015 08:07 AM
apintojr
Jul 23, 2015 10:52 AM
