help me identify this part
Old Jul 20, 2008 | 11:29 AM
Qbrozen's Avatar
Hi folks. I currently am looking to change out my '04 reverse lights for the '05 style. I already purchased the LH unit and have been looking for the RH unit. I see this one posted on Ebay, but why does this not look right? Those tabs sticking out the sides would not fit my car. Yet, it definitely appears to be the correct lens. So what the heck is this from?
http://cgi.ebay.com/ebaymotors/ws/eB...272653524&rd=1
Old Jul 20, 2008 | 01:36 PM
Hotdawwgman's Avatar
Dont buy!!!! looks like it is something completely different
Old Jul 20, 2008 | 02:20 PM
OCG35's Avatar
thats the seal behind the lense... you definitley want to replace that when you remove the original lense... you can get them from the dealer - but it looks like the add includes it, so thats good.
The lense itself looks short though... but it could be the pic
Old Jul 21, 2008 | 10:54 AM
Qbrozen's Avatar
Huh. So how do you get to that seal? Is it flexible and you squeeze it in? I've removed those lenses on my car and I only see easy access to the 2 nuts the hold the lens in and then you pop it out from the front.
Old Jul 21, 2008 | 12:13 PM
G35Papa's Avatar
That is NOT a G35 reverse light.
Old Jul 21, 2008 | 12:52 PM
lexusk8's Avatar
My guess is that this part is the reverse tailamp from the M35/45. I know the reverse tailamps from the M and G sedan look awfully similar but I'm not sure about the actual dimensions. I guess one can go to an Infiniti dealer lot and find out.
Old Jul 21, 2008 | 01:01 PM
Qbrozen's Avatar
hmmm... bit of conflicting info. I guess its just best to avoid it, then.
It is the 2nd time its been listed, so I was thinking of writing to the seller, but I guess if we can't identify the part through consensus, there's not much I can tell the seller, either.
edit:
might be as luxusk said, because i just found this:
http://cgi.ebay.com/ebaymotors/06-07...3286.m20.l1116
Old Jul 21, 2008 | 01:31 PM
OCG35's Avatar
when you remove the taillights and/or reverse lights there is a seal (the dealer lists it as a "packing seal") - it goes between the back side of the assembly and the trunk lid (on the inside)... it's easier to show than write - but when you remove the lenses you'll see it - you can't miss it.
On the actual G (apparently pic is not) - the seal is seperate... like a gasket - you position it prior to bolting the assembly back on.
Old Jul 21, 2008 | 01:34 PM
OCG35's Avatar
edit:
one thing to consider is that some vendors use the same picture for multiple applications - even though they have the car specific part available... If I were in the market for 05-06 reverse light, I check a salvage yard first.
Old Jul 21, 2008 | 02:57 PM
Qbrozen's Avatar
Well, I see that seal on mine, but it doesn't have those mounting tabs (I thought maybe you were referring to an inner seal that I can't see). Plus, something else I forgot to mention, the taillight in the ebay auction has a black housing, while the G35 ones I have seen (including mine) have an orange housing.
You are correct, it could be they just used the wrong picture, but I think more likely they have just listed the part incorrectly. I've sent them an email. If they do have the G35 light, maybe they'll let me know.
Old Jul 21, 2008 | 03:56 PM
OCG35's Avatar
the tails have the tabs (the little part that stick out with holes in them)... I couldnt remember if the reverse did or not - I was thinking they did but I could be wrong (I've only taken mine off once)
Old Jul 21, 2008 | 05:10 PM
maliy06's Avatar
i was looking at that thing also, i need one also,
its not from a G35.
Old Jul 21, 2008 | 05:25 PM
g35freak86's Avatar
No matter what anyone says. That is NOT a g35 sedan reverse light. Looks nothing like that. Even the seal.
Old Jul 22, 2008 | 11:20 AM
Qbrozen's Avatar
i wrote to the seller and he corrected his ad and thanked me for pointing it out. He is now selling it as an M35/45 light.
The hunt continues!
Thanks for everyones' help.
s8n
Jul 31, 2015 01:37 AM
s8n
Jul 30, 2015 04:47 AM
