Disappointing 1/4 mile run - me = bad driving
Old May 6, 2004 | 12:12 AM
belerin's Avatar
I just went back up to the 150-shot and went to the track tonight. Only got one run. My 60ft was 2.3 and did the quarter in 13.6 and 108 mph. I had run better with the 125-shot, guess it wasn't my night. I didn't spray in 1st, but all of 2nd - 4th. It seemed like a solid run, hardly any wheel spin or clutch loss at all.
’03 G35S 6MT, black/black:
-Zex n20 Kit 150-shot & Bottle Opener
-Amsoil Air/Oil Filters & Oil
-Digital Nitrous Pressure Gauge & A/F Switch/Gauge
-Pressure-based Bottle Warmer
-MSD Window Switch
Old May 6, 2004 | 08:37 PM
BobbyD's Avatar
Re: Disappointing 1/4 mile run - me = bad driving
Your mph indicates you have enough power for a 12 sec slip, provided you have traction. I suspect your spinning the tires or your clutch can't handle the extra power. Try spraying in fourth gear at say 3000 rpms and watch your tach. If your rpms increase, but the speedometer doesn't move your clutch is slipping!
2003 G35 Sedan 6MT
14.13 @ 99.55 (stock)
Old May 6, 2004 | 11:09 PM
court's Avatar
YOU ONLY HAD 1 RUN. MAYBE YOU DID SOMETHING WRONG OR TIRES WERE SLIPPING IF YOU HAD MORE THAN 1 RUN YOU MIGHT HAVE DONE BETTER!
04 G35 Sedan Blk/Blk
Nissan Badges
Tein S Tech
Old May 7, 2004 | 10:23 AM
belerin's Avatar
Thanks for the comments. I did run 12.96 with my 125/135-shot earlier this year. I thought I would get back in the 12's with the 150. All test runs I had done on the street didn't appear to give me any wheel spin or clutch slip and it didn't appear to happen at the track either, but I guess its sometimes difficult to tell when you are heading down the track with adrenaline pumping. :-)
THanks again. I'll give it anothe go next week.
Regards,
Steven
-MSD Window Switch
Old May 7, 2004 | 11:47 AM
Catatafish's Avatar
If you don't record the altitude, temperature, barometric pressure, and dew point your comparisons are very loose. Are the times you're listing "corrected" or raw data?
2004.5 Coupe/5AT/Ivory/Everything but chin spoiler/Z Tube-Popcharger/Crawford V5 Plenum on the way
Old May 8, 2004 | 06:50 PM
Xmax's Avatar
Try getting one step colder plugs, they might help a bit, you will lose hp N/A, but when you use the nitro, you will see the gain there. Just a thought
Shift_DEZ' NUTS
www.midnightimpulse.com
www.clubg35.com
Old May 9, 2004 | 12:00 PM
belerin's Avatar
The data is raw data since I was at the track and not on a dyno. The temperature was 71 degrees as sea level, not sure about the humidity or barometric pressure. I do have 1-step colder plugs, denso's.
-MSD Window Switch
Hasanbaloch
Feb 29, 2024 08:45 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
Blakearold
Aug 19, 2015 10:20 AM
newg37
Jul 26, 2015 09:32 AM
