Service Code 0442 next step? Help please
Old Sep 4, 2008 | 09:16 AM
sergio3986's Avatar
Own a 2003 G35 sedan
I did the self diagnose, and got engine code 0442
first thing the service manual refers to is the gas cap. I tighten up, and reset the ECU. But it has come back now 3 times. Could be the gas cap need to be replaced. Just wondering if anybody has experienced this code and what was at fault. The service manual list many other things other than the gas cap.
I have 190,000KM or 118,000miles how ever you want to look at it.
Thanks in advance!!!!
Old Sep 4, 2008 | 12:46 PM
ttrank's Avatar
Grocery getter
Could be that or the fuel fill hose recall. Sounds like there is a air leak.
Old Sep 4, 2008 | 01:06 PM
sergio3986's Avatar
Is this a new recall?
I had the cam and fuel hose recall completed last November. I guess I should take it in to get it checked out. Or maybe just buy a new gas cap and see if t goes away. Just don't want to waste the money on a gas cap if it isn't that
Old Sep 4, 2008 | 01:17 PM
lexusk8's Avatar
I got a similar code long time ago, and I started up a thread about my experience with it:
https://g35driver.com/forums/g35-sed...ine-light.html
Basically it turned out to be a loose gas cap. I retightened it and the SES light went away after something like 100 engine start-ups. Just be patient and it should work the same way for you hopefully.
Old Sep 4, 2008 | 01:35 PM
sergio3986's Avatar
Nice! Thanks, hopefully it's only that. Will wait and see what happens
Old Sep 4, 2008 | 02:32 PM
ttrank's Avatar
Grocery getter
I thought you had your code cleared and it came back. Sorry.
lexusk8's right
Old Sep 4, 2008 | 03:26 PM
reconJDM's Avatar
I had the same problem until my friend who is familiar with the problem suggest maybe I apply some type of (silicone or WD40) the rubber gasket on the gas cap, because it could be dried up and won't make contact with the filler neck, causing the SES engine light.
Old Sep 4, 2008 | 04:06 PM
sergio3986's Avatar
Correct I did clear my code by the pedal method and it came back. so maybe my gas cap is in need of replacing? or something more serious?
Freeman186
Sep 6, 2023 10:07 AM
Detailed Image
Sep 8, 2015 02:42 PM
Rhinos7777
Sep 6, 2015 05:36 PM
n2fooz
Sep 4, 2015 07:46 PM
Detailed Image
Sep 4, 2015 08:35 AM
