Just bought 03 Sedan w 97K, what maint should I do?
Old Sep 5, 2008 | 09:53 PM
4DRSS's Avatar
Arrow Just bought 03 Sedan w 97K, what maint should I do?
My mom just purchased an 03 sedan with 97k on the clock. I would like to give it a good once over to make sure this car will give her trouble free service for a few years. I was thinking an oil, tranny, and diff fluid change would be a good starting point. What is the recommended tranny fluid change interval? How about the diff? Does the tranny just use standard ATF or do I need to use Nissan specific fluid? What fluid does the diff take? Sorry for the questions, car didn't come with a manual.
What else should I look for? Anything else you would recommend doing?
Thanks!
Old Sep 5, 2008 | 09:58 PM
eljoker's Avatar
go FI
Old Sep 5, 2008 | 10:02 PM
4DRSS's Avatar
Oh and I am currently searching... thought someone might be nice and prevent me from having to read through 100's of posts
And what does go FI mean?
Old Sep 5, 2008 | 10:04 PM
joedaddy1's Avatar
you have to use Nissan Matic-J ATF ONLY, no subs.
also, take a look at the drive belts to see if they are in good condition.
just a minor tune up is all u need.
Old Sep 5, 2008 | 10:05 PM
4DRSS's Avatar
Thanks! I figured as much on the ATF, my Titan was the same way.
Old Sep 5, 2008 | 10:11 PM
6spSEDANFTW!'s Avatar
Originally Posted by eljoker
go FI
moron....
j/p
anywho, focus on fluids, belts and misc.
Change oil, flush the radiator, if u know how or pay, do the same for the tranny, I wouldn't bother the diff. Check all belts and replace if needed. Change fuel filter and eighter replace or upgrade the air filter. Replace spark plugs and spark plug wires. Check tires and brake pads and if needed replace them. Wouldn't hurt to do alignment on the wheels. Check level of the brake fluid and power steering fluid. I think that should cover most of it.
Old Sep 5, 2008 | 10:16 PM
eljoker's Avatar
I dont know i found a coupe for $14,000 with 98k so i dont know if its worth the money right now.
one thing for sure make sure you cover as much know as you can so if somthing does happen you know you did your best to prevent it.
Old Sep 6, 2008 | 01:15 AM
Texan1's Avatar
Q50 Red Sport 400 RWD
you know air crammers, Forced Induction--supercharger, turbocharger..
I would do oil chg., ATF fluid chg, diff. fluid chg., coolant change, drive belts, if battery is original--change that thing--trust me, it is very difficult to change in the parking lot of auto zone, don't learn the hard way on this. It is still hard at home as you need 2 sets of small hands and it sucks the big one. Change the air-filter, (in cabin filter too, but that is not as high priority), check the brake pads for meat, and tire tread-depth too and change as needed. When you get new tires, get an alignment. In future, when you do brakes, get new brake fluid too. Am I forgeting anything? Oh, check the air pressure in the spare tire--with a tire pressure gauge, not your hand-gauge Your hand gauge will say its good, but when you put your 3,000 lb car on it, it will look flat.
Anything else, hmm...wash and wax it, mods.....tint Oh, shoot some silicone on the hood hinges, they've been known to stick and cause paint chip on the fender/hood area and do lube the other hinges while you're at it.
I think that's it...not sure about pwr steering fluid though
Old Sep 6, 2008 | 01:41 AM
why? have u ever bled the whole brake system before? its a b!tch...
Old Sep 7, 2008 | 03:20 AM
Texan1's Avatar
then don't do it, here's why I did:
Brake fluid attracts moisture, and this moisture can rust the insides of the brake system. This moisture was not that big of deal 10 years ago, but on ABS brake systems of today, the rust and other debris that accumulates in the fluid can do lots of internal damage, and can be very costly. Brake fluid can also break down over time from excess heat that is created from within the brake system.
Old Sep 7, 2008 | 06:52 PM
i haven't crossed anyone that has had this sort or problem or even heard of anyone having that problem, yes it brake fluid dose attract water, but thats why its a "closed off" system, no moisture will ever get in unless u let it...so no worries there. should last u a life time u just wasted time and money on that carp, sorry my firend
Old Sep 7, 2008 | 08:46 PM
Seymore's Avatar
Take it to the dealer for an oil change and the complimentary 21 point inspection (or whatever it's called). They'll check over the basics and advise you what looks like it's in need of repair. Then decide what you want to do yourself or you want to have a dealer/mechanic do.
You might want to see if they have some sort of more comprehensive inspection that you're charged a little for. Perhaps they'd go through some of the areas that aren't touched by the complimentary inspection. Again, you'll make the call as to what gets fixed by whom.
At 97K, personally, I'd want it to have a thorough check out by the experts. Then I'd have a decent baseline to work from at least.
Old Sep 7, 2008 | 11:13 PM
Texan1's Avatar
Just b/c you have never heard of anyone w/ that problem does not mean that it does not happen. Most people sell their cars off long b4 it's an issue and guess what? It's the 2nd, 3rd owners who really can't afford repairs that get stuck with the repair. I my friend keep cars a long time and at 43kmi, I have this car in tip top shape and intend to keep it that way. Also,
It may be a closed off system, but it still gets dirty and collects moisture overtime.
You don't have to say sorry to me, were you the same guy that said not to do the diff. fluid....well guess what, mine has been done Brake fluid is recommended to be changed every 2 yrs or 30kmiles and you're telling me that spending $25 or so extra to get that done(complete system flush) while I had new brake pads and rotors installed was a waste? That is once in 6 yrs, please. My brake fluid is better than yours
Old Sep 8, 2008 | 12:32 AM
Realtor's Avatar
Inspection at dealership
I think it is $110 for a full inspection at a dealership. They will let you know what you need. I have 95K on my coupe and asked if I needed spark plugs yet. The service writer said it is not due till 105K so wait till recommend service interval. I won't argue saved me the cost of doing the plugs now.
My inspection revealed the axle click problem on the rear, door actuator lock going bad... I got this inspection done before I bought the car and the owner took off $500 to cover the cost of fixing these issues.
Floyd in AZ
Old Sep 9, 2008 | 12:38 AM
the fawk? $25 to get ur brakes bled? were did u find that deal? last time i checked they added a one to the beginning of that number....thats very nice that u have better brake fluid then me, i dont race my g35 (unsure if u do) so my brake fluid will work just fine for now. and i know about cars with high mileage.. 43k miles LAMO...try having a 240sx with 204k miles on it and having a compression of 180 all across...
looky looky i can post pictuers too
and to think this POS ka24de has 204k miles...tisk tisk
