Sticking hood hinges, what's the 'fix'?
Old Oct 23, 2008 | 05:31 PM
itgogitrev's Avatar
I tried to open my hood today and I noticed that there was an unusual amount of resistance from the hinges, as if they were stuck. I slowly pulled it up when it start sticking to get a loud POP from the hinges. They are still intact, but I'd like to be able to repair this quickly. I can open the hood just about 5 inches short of getting the prop rod underneath.
Is there an easy way to get to the hinges to remove/replace them?
Old Oct 23, 2008 | 05:51 PM
RST531's Avatar
take it to the dealership, the should replace it. its a know problem. if not the hinges are (i think) $20 each side. contact riverside infiniti they can help you..
Old Oct 23, 2008 | 05:55 PM
canucklehead's Avatar
i had the same problem. i lubed the hinges up a few times, and allowed the lube to work in to the hinges by lifting up and down. it's been 6 months and i've had no problem since.
just keep applying lube on a regular basis (every other month or so) and the problem should go away.
i know some people have had the problem fixed at the dealer, but if you are out of warranty this should work...
Old Oct 23, 2008 | 06:10 PM
dmitriylm's Avatar
Be careful as this could cause paint damage if not taken care of.
Old Oct 23, 2008 | 06:11 PM
elayman's Avatar
what brand of lube do you recommend?
Old Oct 23, 2008 | 06:18 PM
gary c's Avatar
Our hinges....weather related from being left outside?
WD-40 until you get the hinges replaced, like they mentioned above the
issue with the hinges is a know problem.
Gary
Old Oct 23, 2008 | 07:47 PM
itgogitrev's Avatar
Thanks for the advice! I cracked open the hood a bit and managed to spray down the hinges with a little bit of generic bolt spray lubricant (it's all I have at the moment.)
I guess I'll be hitting up Riverside for some hinges.
What there a TSB or recall on the hinges at all? I'm out of warranty...
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Kelvin Style006
May 23, 2016 03:47 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
