is it necessary to get an alignment after lowering car
Old Oct 23, 2008 | 01:24 PM
4drmadness's Avatar
Hey guys, i put on a 05 revised 350z suspesnion on my car (springs, shocks/struts). Is it necessary for me to get an alignment done? my car isnt pulling on the right or left side, and it has been around a month since i got my car lowered. let me know what i should do and what type of alignment i should get if i need one.
Old Oct 23, 2008 | 01:49 PM
LightsOut's Avatar
SIETESG
i would get an alignment check, cause your camber might be off
Old Oct 23, 2008 | 02:28 PM
g35freak86's Avatar
Hey man, I was in the same situation as you. I got coupe 19's on and 07 z suspension and coupe springs in the rear. I would tell I had more neg camber in the rear once I dropped. It's not a drastic drop so I wasnt in a rush to get an alignment. I put the suspension on in july and just got an alignment in sept. I was about -2.0 on each rear and they got almost both wheels back into spec to -1.3 and -1.4. In other words, I would just go check it checked. It wouldn't hurt
Old Oct 23, 2008 | 02:32 PM
nghiars's Avatar
You should definitely get an alignment now.. the Toe is off in both the front and rear and will cause unnecessary and uneven tire wear. fronts toed out and rears toed in. your wheels will look like \ / in the front and / \ in the rear(not to that extreme but its just so you get the idea.
camber will likely to be more negative than stock. i personally like the negative camber but it will wear your tires out faster with more camber.
Old Oct 23, 2008 | 06:38 PM
4drmadness's Avatar
alright guys looks like my y pipe money will go on an alignment
Old Oct 23, 2008 | 06:51 PM
LightsOut's Avatar
SIETESG
^^^i just got the ypipe should be here soon
Old Oct 23, 2008 | 06:53 PM
dofu's Avatar
20 Year Member
Wait about a week or two before the alignment. If you dropped your car 1.5"+, get the alignment now, and bring it back in to check it a week or two later.
Old Oct 23, 2008 | 06:54 PM
4drmadness's Avatar
hey does anybody know a good place for alignment in OC. appreciate your help
Old Oct 23, 2008 | 07:27 PM
Wannabe6MT's Avatar
-MN G Crew-
Oh geez, i lowered my car on Z springs in front and coupes in the rear, and i have not gotten an alignment done yet... haha
Old Oct 23, 2008 | 08:18 PM
nghiars's Avatar
one of our sponsors HBSpeed does alignments.. they're in FV
rezendvous420
May 31, 2020 01:26 PM
itschuckster
Jul 25, 2015 08:07 AM
Soumilg
Jul 23, 2015 09:26 AM
beevanhuynh
Jul 23, 2015 01:37 AM
