Urgent Help!
Old Oct 27, 2008 | 04:49 PM
kayveeee's Avatar
Urgent Help!
Okay, i just got my clear corners today and i installed it, i took the blue LED lights from my rear licence plate and place it in the side corner lights. And then when i install the bulb it blinked once then it jus turned off, now both my side corners, rear licence plate lights, and my taillights dont go on when i turn the lights on. Did i blew the fuse? If so where is the fuse located and what is the fuse code called?
Old Oct 27, 2008 | 05:32 PM
mIKE's Avatar
Sounds like you did. Check your fusebox diagram...
Old Oct 27, 2008 | 05:57 PM
kayveeee's Avatar
i did but i dont know which fuse it is, the diagram does not say the lights, its a code. Im not sure which one it is.
Old Oct 28, 2008 | 02:06 PM
kayveeee's Avatar
I just checked all the fuse and they all seem fine, mayb it's the wires? anyone know?
Old Oct 28, 2008 | 03:32 PM
awong's Avatar
just bring it in to infiniti and they we gladly fix that for free cause that happen to me and it was the fuse
Old Oct 28, 2008 | 06:53 PM
kayveeee's Avatar
i asked the dealer today, they said they would charge me $92 an hour to figure out the problem.. so tomorrow im going to take it to the shop hopfully it wont be anything expensive.
Old Oct 29, 2008 | 04:49 PM
kayveeee's Avatar
hrm.. i guess no one had this problem or know how to fix it?
Old Oct 29, 2008 | 05:10 PM
ckkone's Avatar
Did you check them with a volt meter or test light?
Test light would be the easiest way:
With the cars ignition on take the test light and hook it to the Neg side of your batt (or any ground). Then go to the fuse Box and look at the fuses they have a small metal tab on each end, touch the tip of the test light to each metal tab on every fuse. When one side of the fuse lights and the other side does not then you found the blown one.......
Old Oct 29, 2008 | 05:29 PM
MikeYo's Avatar
i had the same exact problem and it was a relay for me.
Old Oct 29, 2008 | 07:01 PM
kayveeee's Avatar
o i c, i took it to the shop today and they said they need the car for one whole day to find the problem... and silverbg how did you end up fixing it and what was wrong with it? was it expensive?
Old Oct 30, 2008 | 12:25 PM
MidnightG35X's Avatar
The fuse is underneath the battery in that fuse compartment. This topic has come up at least 5 times, we should find a sticky for it
edit:
https://g35driver.com/forums/audio-v...de-marker.html
I think this should be in the FAQ section at the very least.
Old Oct 30, 2008 | 10:22 PM
kayveeee's Avatar
okay so i took it to the mechanic shop today for 1 whole day.. and they couldn't find out the problem, they checked all fuse even the 1 hidden and all fuse are good. So now they told me to go to the dealer and get it done. anyone know the price range im looking at to get this fixed?
Old Oct 30, 2008 | 11:08 PM
03Sg35's Avatar
Arm and a leg lol sorry Did you try working backwards, take the corner light plug and test it, see if it is getting power? Check the relay fuse box near your battery! If your fuses are all good maybe its the relays, If you remove your battery you will see a black box, its the IPDM--> controls most electrical components and more, check that it has fuses there also. if you dont feel like you can do this take it to infiniti and get raped, unless you have warrenty. Also I would say put all stock corners on and play dumb when you go.
350GT-DOT
Accessories
Jun 6, 2010 03:28 AM
HITMANVQ35
Intake & Exhaust
Apr 6, 2010 10:21 AM
kennymo
Dec 2, 2009 01:37 PM
