03-04 vs 05-06 stock exhaust.
I am selling my 05x stock exhaust, and someone with an 04x wanted to buy it, but I have no clue about the exhausts for the 04x. Would it fit for him or would it require modifications?
y-pipes are the same 03-06.
The 05/06 mid pipe fits the 03/04, and is a recommended easy upgrade. The 05/06 is lighter and slightly less restrictive. You will notice a small performance gain on the 03/04 just by swapping to the 05/06 mid pipe.
The 05/06 muffler hangs from the chasis slightly differently than the 03/04, but bolts to the mid-pipe the same. There is no other difference in the muffler itself, just the hanging method, so stick with the 03/04.
If you own a 03/04 and want to stay with a stock exhaust, I highly recommend upgrading the 03/04 midpipe to an 05/06 while staying the the 03/04 y-pipe and muffler.
As for the X vs. non-X, the exhausts are identical, no worries. Suspension mods is a different story though...
03 and early 04 midpipes are huge and restrictive. Look at the difference between this one and the 05/06. Oh and the coupe one is in the background.
Y-pipe is different on the X. RWD y-pipe will not fit X's, it'll be hitting some part, I forgot. But an X y-pipe will fit both models.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
