Hey guys,
Ok I turned my heater on finally and its so weird only the right two vents work. I made sure duel climate were both on 85 degrees and only the right side works. The two vents by me spit out cold air....... why do you think this is happening? I searched around the net and couldnt find anything. My car is running fine and I have no check engine lights.
Thanks!
Thanks!
i have the same problem except i have my SEC light on and its the first O2 sensor(idk if thats causing the problem for me)
the 2 vent on the passanger side get VERY hot while mine just blow warmISH air and both sides are on 90
AARONHL
close
- Join DateOct 2007
- LocationɷCONNECTICUTɷ
iTrader Positive Feedback100
iTrader Feedback Score(15)
Liked:121 Times in 113 Posts
Check the in-cabin sensor and make sure both connections (including the hose) are connected. It is located underneath the steering wheel.
I am having heater problems as well right now.
AARONHL
close
- Join DateOct 2007
Sweet thanks for all the help guys! I did install the TVandNAV To Go plus the audio adapter as well!!
AARONHL
close
- Join DateOct 2007
Yea, tell me about it, my climate control is acting strange right now too!
