Need Help with Wheels and Tires 18*8
Old Nov 16, 2008 | 06:02 PM
jtspea2's Avatar
I have a 2003.5 sedan with z revised springs. Will 18*8, not sure about the offset they are they factory g37 or upgraded 08 g35x wheels. The tires are 225/50/18 will this work on my sedan, or look stupid. Any suggestions would be appretiates. Already searched forum and couldn't find much on this setup.
Thanks
Jtspea2
Old Nov 16, 2008 | 06:39 PM
gtbigup01's Avatar
Not sure about 03.5, but I have a 04 and I have 8.5 wide rims with 245/45 all around. No probs
Old Nov 17, 2008 | 02:13 PM
jtspea2's Avatar
Any body else
I need info ASAP, before I purchase this combo.
Thanks
Jtspea2
Old Nov 17, 2008 | 02:35 PM
jran76's Avatar
If they came off an 08-09 sedan, they should work on an older model sedan with no issues. If they are off of a coupe, they will fit, but you may rub slightly and require minor fender rolling.
To fully answer your question, we would need a lot more information on the wheels.
Old Nov 17, 2008 | 03:52 PM
jtspea2's Avatar
Wheels
I believe they are off an 08 g35x, however I cannot find their offsets. I believe the factory g37 coupe 18's and these are the same, same tires 225/50/18 18*8.
Also I am dropped on revised 350z, anybody know if this setup will work.
Also I believe the new infiniti wheels are made by enkei, can anybody confirm this, and their weight.
Any help would be appretiated.
Thanks
Jtspea2
Old Nov 17, 2008 | 04:11 PM
jran76's Avatar
I can't find anything that indicates the G37 coupe and G35xS sedan have the same wheels. Both use the same size tires, but the Infiniti site lists the 2009 G37xS as having 18x7.5.
I hate to say this, but unless you can find out exactly what you have, it is really hard to tell. The only car that I can find that currently uses 18x8 and 225/50/18 is the base G37 coupe. If this is the case, I would guess the offsets are around +30, in which case you may rub a little.
Old Nov 17, 2008 | 07:49 PM
rpg35's Avatar
I have the 08 g37 coupe wheels on my car. 18x8 with 225/50/18. 43 or 45 offset. Very similar to 03 sedan offset. The lug nuts changed on these new G cars so your 03 lug nuts will NOT work.
Here is a link to my thread in the sedan picture share on the second page which has pics of my car. I am about to lower and potentially paint the lower sills.
https://g35driver.com/forums/g35-sed...-03-sedan.html
Old Nov 18, 2008 | 11:31 AM
jtspea2's Avatar
Thanks for the Help
Thanks for the pics RPG,
Those are the rims I was looking to purchase, however the person on ebay had a reserve of $1500 and the highest bid was $1000, so it looks like I may be going a different route.
Thanks For the Help
Jtspea2
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
