90k maintenance
Old Nov 26, 2008 | 11:05 AM
BigGrz's Avatar
90k maintenance
Can any of you all-knowing-G35-masters help me out with recommendations for a 90k mile check/tune up for my '04.5 Sedan?
Also, for my oil changes I typically have the change done with the Valvoline Max Life every 3k miles. Is there a better type I should use?
Thanks in advance!
Old Nov 26, 2008 | 11:37 AM
canucklehead's Avatar
wow, big mileage for an 04.5! any major mechanical issues yet?
as for the oil, there are many differing opinions here and you will get no consensus. but if you are religious about your 3k mile oil changes then any high quality 5W-30 would suffice. replace the oil filter with each oil change.
by my calcs you are changing oil at least 7 times a year, so i'm not sure you would want to pay the premium for synthetic. nor would it pay significant dividens
Old Nov 26, 2008 | 04:48 PM
AARONHL's Avatar
Clean your Throttle Body, unless it has been done recently. It's something that is over looked, especially when you change an air filter.
Old Nov 26, 2008 | 05:32 PM
ttrank's Avatar
Grocery getter
My car's body has almost 81k on it.
Old Nov 26, 2008 | 05:38 PM
naughty240's Avatar
Spark plugs are due/over due depending on if you buy into the 100k theory. Check the spark plug tubes for oil and if your lucky the valve cover gaskets are not leaking.
Belts
Up to date on system flushes
Air filter
Throttle body
In Cabin filter
Marlin84
Apr 1, 2020 12:52 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
c_elliott83
Sep 25, 2015 07:55 AM
DRG35R
Sep 16, 2015 05:33 AM
