should i go for revised or unrevised springs
Dec 3, 2008 | 11:40 AM
It is my understanding the front struts from the coupe , rwd sedan and the z will not work on an x. If they did you could use the coiloves made for those cars.
I would contact FlyingLumpia (screen name) he has done alot of different suspension mods to his car. There is also a sticky on the top of the sedan forum for lowered x's. In this he talks about the different things he has done as well as others.
Reply 0
Dec 29, 2008 | 03:34 PM
i've looked around i haven't found anyone with all out coupe spring and shock setup.
i was thinking of running full coupe, should be roughly 1inch all around. if that doesn't make me happy i should be able to scoop up just Z fronts. and leave the coupe spring paired up with the coupe shock... or is it better to run Z struts for the rear.
Reply 0
Dec 29, 2008 | 07:09 PM
Quote: i've looked around i haven't found anyone with all out coupe spring and shock setup.
that's because the struts on the rwd and the awd cars are different and can't be swapped between models. otherwise you COULD use the coilovers.
Reply 0
Dec 29, 2008 | 10:59 PM
Quote: that's because the struts on the rwd and the awd cars are different and can't be swapped between models. otherwise you COULD use the coilovers.
i never said anything about FRONT STRUTS did I,
all rears are interchangable, but like a said i never found anyone use COUPE SPRINGS all around. And for the owners that run Z front/ Coupe rear SPRINGS, which struts are being used for the rears, Z or g35c's.
I got a deal for g35c all around.
Reply 0
