18 350z track wheels, what tires to use?
Old Dec 9, 2008 | 12:01 PM
jtspea2's Avatar
Tires
I just found a link that has tire heights and its says the factory tires 215/55/17 are 26.31mm I guess tall. A 235/45/18 tire will be 26.33 tall, being on an 18 wheel does that imply that the actual height of the 18 setup will be 18inches + 26.33 tall as opposed to 26.31 + 17 inches tall on factory. I really want a slightly larger setup so my wheels and tires fill my wheel wells alittle better.
Jtspea2
Old Dec 9, 2008 | 01:02 PM
G SEDAN's Avatar
Originally Posted by jtspea2
If I went with the 235/45 on a 4 corners how would that affect the rear wheels that are 8.5 as oppossed to 8. I guess it fits but would it look funny, or perform different. Also any body have any pictures of a setup similar to this.
G-Sedan are your wheels painted or powdercoated different than factory?
Thanks
Jtspea2
You wont be able to tell you're running 235/45/18 all around unless they are reading the size on the sidewall. The .5 inch difference will not matter much when the tire is mounted.
My wheels are powdercoated in the center and polished on the lips. I had it re-done after running stock finish for a while.
Old Dec 9, 2008 | 01:47 PM
jtspea2's Avatar
tires
How as the finish worn, I am in the process of getting this done but with a slightly darker gunmetal powdercoat in the center. How does the polished lip look in the long run.
Thanks
Jtspea2
Old Dec 9, 2008 | 01:50 PM
Jeff92se's Avatar
Red Card Crew
Like any bare aluminum, it will need maintance. Perhaps a regular coat of wheelwax would help keep the shine longer
Old Dec 9, 2008 | 03:52 PM
G SEDAN's Avatar
I usually keep the lip polished with mothers aluminum polish and a coat of wheel wax to protect it. It's not really wet to california so the chances of rust is next to none. The powdercoat I got is quality work it's still shiny and sick like the day I got the wheels back.
A quality paint job is a quality paint job; with proper normal mainteanance, it souldn't wear, fade, or crack at all.
Old Dec 10, 2008 | 04:54 PM
jtspea2's Avatar
Tires
Will 245/45/18 all the way around work? without rubbing or would I need to roll the rear fenders. There are more of this size available.
Thanks
Jtspea2
Old Dec 10, 2008 | 05:32 PM
G SEDAN's Avatar
Thanks
Jtspea2
that woud work. I'd have the rear fenders rolled just to be safe. I rubbed on hard turns when the fenders weren't rolled.
Old Dec 11, 2008 | 11:11 AM
jtspea2's Avatar
Tires
Would running that size tire on all four corners negatively affect performance? Would I be better off running a staggered setup or a smaller tire 245/40.
Also what tire would you suggest for wet and dry performance.
Thanks
Jtspea2
Old Dec 11, 2008 | 03:14 PM
G SEDAN's Avatar
^ No will not affect it and you most likely wont feel it. I'm running 245/45/18 all around now.
As far as brand and model...look for your prefrence (grip, tirewear, quiet,) etc, and do your research on tirerack.com
as far as 245/40, its going to be lower profile so you better have a drop to accomodate the gap. lower profile also = harsher ride and more prone to pothole damage. UP to your preference once again.
Old Dec 11, 2008 | 03:50 PM
TurTLe*'s Avatar
would that .5 width make a diffrence when you rotate the wheels?
i'm thinking of getting track wheels for my X and i wanted to rotate the tires... would having in the front mess up traction/ grip in any way. I know it makes more sense to run teh 8.5 in the rears but what if its the same tire size .
Old Dec 11, 2008 | 06:24 PM
G SEDAN's Avatar
OH....it changes everything that you have an X. I seriously would just run same rims all around on the X.
you know Sean (SXCXEX) has a set of track wheels nonstaggered for sale right
Old Dec 11, 2008 | 07:09 PM
iiiiiekoiiiii's Avatar
Gsedan, how light are those compared to g37 19s cause i Feel a pretty good difference goin from stock 17s to 19s.
Im thinkin about gettin these to switch around sometimes. Ima get after sum nice light oems.
Old Dec 11, 2008 | 07:42 PM
G SEDAN's Avatar
these wheels are 18.xx lbs front and 18.xx lbs rear. SUPER LIGHT
Old Dec 11, 2008 | 09:30 PM
TurTLe*'s Avatar
i know he DID have them, sold now but either way he doesn't want to ship so yea... i would of jumped on it when he had them for sale, but local pickup would be a JOURNEY for me chicago to cali and back.
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
