painting the dark gray side sills ( ur advices)
Originally Posted by OCG35
^^^ $1000? I got my window trim, door handles, side sills, bottom of front bumper, entire rear bumper, mirror frame and taillights painted for $1000.
just the side sills (plus front & rear lower) was only $250-$300.
Hi again
I just come back from the dealer
He said:
the price would be 700$ for painting the sills and the bumpers
soooooooooo expensive
I will look for another shop
also he said there are some rubber strips at the bottom of the doors that cannot b painted ... but I'll be able to remove them.
have u guys tried to do something on them ?
thanks in advice
thanks in advice
thanks in advice
thanks in advice
Originally Posted by DaveB
This ain't Socal There isn't an auto paint, specialty, and/or tuner shop on every corner.
It shouldn’t cost more than a few hundred bucks to paint the side sills.
Hi again
have u guys tried to do something on them ?thanks in advice
Painting rubber is not a good idea - painting plastic is fine.
When you say you will remove it – I presume you mean for painting only… you definitely do not want to remove it for good.
some people have had them painted - most shops recommend against it though since its rubber (the paint will crack).
painting them is still the best solution .... im gana try it
i think most shops charge alot cus of setup costs...to spray once..my cusin said it costs about $100 with the proper stuff..plus the paint itself plus the labor? prep work n that stuff...?
they look at it at a base cost for the shop. plus labor.paint (do ur colors cost more?)
but ya if u can, do it yourself, learn a new skill..hell have a some new tools while at it for the price of a shop....
im at that dilemma right now too. got my oem aero kit front lip n guards...need to spray it a DP color. sold my compressor.n have a ok spray gun and no longer a place to spray.
plus its illegal to be spraying paint..u can get busted if someone rats on you. cus of the chemicals n stuff...as far as i know.i could be wrong...last i was told.
but if there's only a few shops where the OP lives, then its supply n demand. =) but the dealer doesnt wanna do it cus they know they'll have to re-do it if it messes up...they rather be "DUMB" and stick to their protocols.
as for the rattle can way..u can do it that way...u gotta be good at sanding,spraying.wet-sanding....i've seen some rattle can miracles..
still - $1K is ludicrous... even without a bunch of competition it shouldn’t cost more than a few hundred.
#30
I meant remove them completely ....but, I think sooo, it might be a bad idea
I'm not telling you what to do - just suggesting not to paint it.. many of us have painted sides and left the rubber as is - looks fine.
