pot hole!
Old Dec 19, 2008 | 12:09 PM
g35couture's Avatar
pot hole!
hi people,recently i had changed my springs to ebiachs coupe lowering springs on my 03 sedan, and yesterday on the freeway (57n) i hit a pot hole on the front driveside. Now i notice when im driving 80MPH+ my car vibrates in the front really bad but when i brake or make a really slight left turn it will stop for 1 second. what could be the problem?
Old Dec 19, 2008 | 12:24 PM
gtrefever's Avatar
alignment.
Old Dec 19, 2008 | 12:40 PM
RADIOGUY21's Avatar
possibly could have bent a rim. May want to get it checked out and rebalanced. Also since you lowered the car you should get an alignment anyway after the springs settle.
Old Dec 19, 2008 | 12:51 PM
jack_burton's Avatar
bent rim...sorry dood
Old Dec 19, 2008 | 12:59 PM
g35couture's Avatar
thanks for the help guys i will check it out soon as i get home from work
Old Dec 19, 2008 | 01:11 PM
ttrank's Avatar
Grocery getter
My first guess would also be a bent wheel. Also get your alignment checked because it is probably off too.
g35couture's Avatar
ok i went outside and check the wheels, theres no crack or bend.. so im guessing could it be an aligment or wheel balancing?
Old Dec 19, 2008 | 01:21 PM
6MTFTW's Avatar
Sometimes, when a wheel is bent, you won't be able to see it while it's idle. You'll have to put it on a wheel balancer, and you can see it wobble as it spins.
-Jerome
Old Dec 19, 2008 | 01:43 PM
Mustang5L5's Avatar
Could be bent on the inside.
Either way, you need to get an alighment after the springs settle, and then you could prob have that one wheel rebalanced. They will tell you if it's bent when they put it on the machine
What size are your rims?
Old Dec 19, 2008 | 01:51 PM
AceG35X's Avatar
Wheel balance fell off?.. did you check if their on there? If not that then get an alignment done you'll figure it out after that.
Old Dec 19, 2008 | 05:08 PM
throw your spare on the suspect wheel...see if the vibration goes away
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
G35xdriver04
Nov 7, 2015 08:31 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
AesonVirus
Engine - Exhaust
Sep 20, 2015 01:54 PM
JustinMKN1
Sep 18, 2015 03:40 PM
