Take apart the front suspension?
Old Dec 22, 2008 | 05:03 AM
Heist.'s Avatar
Exclamation Take apart the front suspension?
I am having some trouble with getting the spring off the shock ( fronts ) the top bolt twists in unison with the suspension rod. Is there any trick to getting it off? I already did the back with the 350z suspension and now i need to get the top off to do the front. Any help is huge! thanks!
( 03 g35 sedan )
Old Dec 22, 2008 | 05:12 AM
6MTFTW's Avatar
Impact gun.
-Jerome
Old Dec 22, 2008 | 05:13 AM
Heist.'s Avatar
Originally Posted by 6MTFTW
Impact gun.
-Jerome
yeah it looks like my only option at this point.. just have to find someone with one
Old Dec 22, 2008 | 05:16 AM
6MTFTW's Avatar
That or see if you can grip the shaft with something. But, if you try that, make sure you don't scratch the shaft...
Old Dec 22, 2008 | 05:21 AM
Heist.'s Avatar
yeah i tried to pull that off for a while today just hard to manage alone. I will see what I can do tomorrow thanks for the help though!
Old Dec 22, 2008 | 11:55 AM
taylordio's Avatar
i used two different sized wrenches. a small one to grab the center rod and then one to fit on the nut. by the time you get the nut to where you cant use the smaller wrench anymore, it shouldnt be spinning in unison and should come right off
Old Dec 22, 2008 | 12:27 PM
G35Papa's Avatar
I hope your compressing the spring before you take the bolt off.
Old Dec 22, 2008 | 12:30 PM
Hi-TechG35's Avatar
^You dont really have to. Just lay it down on the ground aim away from yourself or anything else that may get damaged and put the impact gun to it. You can go to AutoZone or Pepboys and get one for about 60.00. and they are electrical so need mto worry about the battery draining.
Old Dec 22, 2008 | 01:06 PM
Max626's Avatar
^ thats foolish
If your going to reuse the struts get a cloth and a vise grip that can fit inbetween the springs our spring are very tightly coiled so i migh be hard to find one that fits. IF it fits clamp the vise grip and slowly remove the top bolt, again make sure u have the spring compressed. What you should of done since it seem liek your using basic hand tools was losen that bolt first while it was on the car but fully just slightly. If the vise grip trick doesnt work have a freind pull the bottom of the strut while u break lose the top bolt. Hope that helps
Old Dec 22, 2008 | 01:56 PM
G35Papa's Avatar
Yeah...aim it at the neighbors house you don't like
Old Dec 22, 2008 | 11:51 PM
GrocryGettr's Avatar
I predict a future post that starts off like this...
Well, I'm in the hospital now recovering...
Old Dec 23, 2008 | 12:29 AM
Sponger's Avatar
6MT Brembo Coupe
Stick the strut assembly in a vice and use a deep offset wrench like the one in this link along with another combo wrench to prevent the piston from spinning. DO NOT use vice grips, etc. on the piston.
http://www.sears.com/shc/s/p_10153_1...00100600&aff=Y
Old Dec 23, 2008 | 01:01 AM
AARONHL's Avatar
I used a vice to grip the square tip. I had a closed end wrench on the nut before it was held in the vice. After a couple knocks with a hammer the nut was free.
Old Dec 23, 2008 | 05:32 PM
Heist.'s Avatar
thanks for all the help! When I get a day off work I'm going to get offset wrench and give it a try! Thanks again for all the help and I will tell you how much the hospital fee it
Old Dec 23, 2008 | 07:12 PM
Trbulnt's Avatar
DO NOT USE AN IMPACT WRENCH!! This may seem like the easy way out. What can happen is you try and remove the nut and end up still spinning the shaft which basically destroys the inside of the strut assy. Take the time to do it properly and use the correct tools....and please use a spring compressor.
