Normal?
Old Jan 9, 2009 | 12:01 AM
AARONHL's Avatar
But will it help with the 1 to 2 shift? Yes.
I've heard our flywheel is HEAVY though. Are you saying when I replace my clutch I shouldn't get a little bit lighter flywheel?
Old Jan 9, 2009 | 01:09 AM
absolutg's Avatar
workin...
no one else mentioned it, but change the fluids too. way past 30k, should do it all
Old Jan 9, 2009 | 01:46 AM
AARONHL's Avatar
These G35 clutches seem to not last very long. At 48k miles it might be worked, so does it slip in 5th/6th gear when you are going up a hill and smash the gas pedal?
Old Jan 9, 2009 | 10:25 AM
canucklehead's Avatar
^ a clutch not lasting is entirely reliant on the driver's ability or driving habits. if you drive normally with good technique and stay off the clutch then the clutch will last a long time. if you track your car, or abuse it on the street, then the clutch can wear out very quickly. this is the case in any manual car.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
aaron3719
Sep 29, 2015 10:12 AM
vamarris
Sep 26, 2015 12:56 PM
