Slight steering creak - ideas?
Old Jan 8, 2009 | 07:20 PM
AVATAR77's Avatar
Hi - '05 G35, 47K miles. Noticed a slight creak in the steering column, usually when the car is cold and I turn the wheel more than 180 degrees. I've never really noticed the problem once I get going. The sound seems to be coming from inside the cabin, not outside. Any ideas? I had thought compression rods, because everyone seems to have problems with them, but I honestly don't even know what compression rods are and what the symptoms of a bad compression rod are. Thanks.
Old Jan 9, 2009 | 08:46 AM
lexusk8's Avatar
Sounds like the dust boot in your steering column may need to be lubricated. The same scenario happened to one of my previous cars.
Old Jan 9, 2009 | 12:45 PM
snotf's Avatar
i had that for a while. got my car washed and it either went away then or with the oil change my friend did for me the next day. either way, its gone.
Old Jan 9, 2009 | 08:17 PM
Redpit10's Avatar
There is some kind of spring in the steering wheel (I beleive it is called a clock spring, I could be wrong). Mine used to do the same thing, and I got the spring in my steering wheel replaced under warranty and no issues since.
rezendvous420
May 31, 2020 01:26 PM
tiguy99
Mar 1, 2016 11:42 AM
DigitalDeviant
Engine - Intake/Fuel
22
Dec 4, 2015 10:27 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
rping
Jul 26, 2015 09:53 PM
