black headlights
Old Jan 8, 2009 | 09:47 PM
Gbabyyy's Avatar
Unhappy black headlights
i have 05 sedan and just bought black headlights and later realized that it will not work with my car because of the HID lighting system, is their any modification i can do to the headlights to make it work with my car, or should i just return the product?
Old Jan 8, 2009 | 09:57 PM
Joe_Camel's Avatar
I don't know what you can do, but I'd definitely go with a complete lack of light vs. HIDs! I hope you figure out how to swap 'em.
Old Jan 8, 2009 | 09:58 PM
G SEDAN's Avatar
are the black headlights halogen?
If so, return them bishes!
Old Jan 8, 2009 | 10:03 PM
G35Papa's Avatar
sounds like someone bought the cheapo "JDM" eBay lights. Get your money back if you can and mod your OEMs
Old Jan 8, 2009 | 10:11 PM
Gbabyyy's Avatar
haha they are halogens, f*** ok guess i gotta return them.
Old Jan 9, 2009 | 02:14 AM
dmitriylm's Avatar
This is exactly why you do your research before buying junk replacement housings.
Old Jan 9, 2009 | 09:28 PM
TOPNOTCHSEDAN's Avatar
Wait u could still use them if u wanna open ur old lamps up and replace the inside & the clear cover like i did ....i think theyre called bezels???
Old Jan 9, 2009 | 09:39 PM
dofu's Avatar
20 Year Member
Do they even fit on your 05?
Old Jan 9, 2009 | 10:31 PM
DieselX's Avatar
Aren't those ebay headlights only for 03-04? Return that junk, and get your stock headlights painted instead.
Old Jan 9, 2009 | 11:01 PM
Gbabyyy's Avatar
they do fit, lol and their not from ebay but their still s***, the reason i dont want to open up my headlights is because i heard from several people that when you do, moisture can get inside and mess up the headlights
Old Jan 9, 2009 | 11:10 PM
ILLicit's Avatar
If they fit then your car isn't 05. eBay headlights only fit the 03/04. If the work is properly done, the headlights wont condensate. Have G35Papa do your headlights since your in SoCal, if he cant, I can do them for you, but you'd need to mail them to NYC.
Old Jan 10, 2009 | 12:52 AM
Oh idk about that.. i just know they fit on my 04.... Yea u should just open ur stock and paint them...
Old Jan 10, 2009 | 02:35 PM
godmans's Avatar
time to use those to do a projector retrofit!!
Old Jan 10, 2009 | 03:00 PM
G SEDAN's Avatar
Gbaby has an 05+ sedan.....i've seen his car.
I've only seen 03-04 "JDM black housing headlights" on ebay though.....so maybe someone's carrying them for the 05+ sedans now??
If you properly reseal your headlights.......there wouldnt be a problem at all with condensation. I vote for painting them also
Old Jan 11, 2009 | 01:37 AM
G35Papa's Avatar
If you mod your OEM headlights...there is no need to reseal the headlights after taking them apart. The same seal can be re-used. I've done numerous sets and not one has had any condensation what so ever. When you start mixing and matching parts (OEM with ebay lenses...etc) thats when you could run into a bad seal and using sealants is recommended.
