when to get an oil change when you go with amsoil 0w-30
Old Jan 9, 2009 | 02:08 AM
4drmadness's Avatar
hey guys just put the amsoil 0w-30 in. car seems to be running smoother. ive heard so many stories about changing oil every 3k or 6k. amsoil recommends changing oil every year or so. how long do u think i should wait for my next oil change?
Old Jan 9, 2009 | 06:29 AM
BuckeyeG's Avatar
I run 0-w30 in my G along with a AE013 filter. My brother runs the same in his Maxima and we do oil changes every 6 months. I only drive about 4-5k in that time. We figured that we would half there time to change it just to be safe.
Old Jan 9, 2009 | 10:51 AM
Swivel's Avatar
Moderator
Good advice. I run mine about 6250 miles (10,000 km) between changes. As has been discussed at length in this forum, the only way to tell how long to run your oil for your car in your driving conditions is Used Oil Analysis. But 5k miles should be very safe, I've read some guys are running 7500 miles and even that is conservative IMO.
Are you running the Amsoil AE filter or another brand? If other, you should probably change the filter halfway through whatever mileage interval you choose.
Old Jan 9, 2009 | 12:11 PM
4drmadness's Avatar
im running the amsoil filter as well. ok so im thinking 7k should be good
Old Jan 9, 2009 | 11:04 PM
bythabay's Avatar
7.5k / 1yr... I would get an analysis done after that and if it they say the oil is still good and the wear is low, run it longer.
Old Jan 10, 2009 | 12:54 AM
gtrefever's Avatar
is amsoil 0-30w is the best to use? ive been using moble1 5w30
Old Jan 10, 2009 | 12:59 AM
bythabay's Avatar
If you can afford it, use it, otherwise any other full synthetic will hold up fine for 7500k/6month under normal/severe driving conditions (excluding track use). The amsoil comes with more anti-wear additives and bases to neutralize acidity. This allows you to use the Amsoil for a longer period of time. The 0w30 actually has so many anti-wear additives, that it does not contain the API starburst.
Old Jan 10, 2009 | 01:03 AM
gtrefever's Avatar
ill try amsoil next time i get an oil change how much do they go for usually 5 qts and the filter?
Old Jan 10, 2009 | 01:18 AM
bythabay's Avatar
If you're local, I can get you 5qts signature series 0w30 and an amsoil nano-fiber oil filter for under $70
Old Jan 10, 2009 | 07:55 AM
TurTLe*'s Avatar
how much do those used oil samples normally cost?
Old Jan 10, 2009 | 03:57 PM
bythabay's Avatar
They're around $20 + shipping for a basic analysis, and $30 + shipping for one with a TBN count. These are the prices if you go with blackstone labs, there are other places that can analyze your oil also (even give you particle counts if you are interested in that).
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
