getting a lot of wheel spin when flooring it
Old Jan 11, 2009 | 03:44 AM
4drmadness's Avatar
Originally Posted by Mustang5L5
If the weight distribution is even, there is usually no problem lighting up both tires with an open differential. It's been done many times.
The OP's biggest problem is tires. What's more than likely happening is that he's spinning up the right inside tire and just sitting there baking it to kingdom come. If he had a set of stickier rubber, he would probably launch better and come out with little wheel spin.
He could also learn to feather the gas pedal off the line and not hit it so hard.
An LSD does help with launching if you have good tires. If one of the tires breaks traction, the other one still pushes and does help in allowing the other tire to regain traction rather going into a "1 tire fire" situation.
hey thanks for the good info. will get new tires asap
Old Jan 11, 2009 | 11:25 AM
OCG35's Avatar
Originally Posted by DaveB
It's either your tires, the surface, or both. It has absolutely nothing to do with the fact that you don't have an LSD. An LSD WILL NOT improve off the line traction. My 03 sedan with the sport package does not have LSD and it has absolutely no problems lighting up the 17s in two perfectly uniform lines.
not true Dave... as you know I had significant difficulties with traction prior to Quaife... I used the same tires before and after install and saw an improvement.... I do agree that tires make a significant difference though - as I got better 60' and cornering when going from Kumho Ecsta ASX to Toyo T1R... but to say LSD wont help is a false statement (at least on my car).
Having that been said – LSD is not at the top of my bang for buck mods… There are many other more cost efficient mods (unrelated to traction) that I would recommend first. A decent LSD makes hard cornering much more enjoyable for sure, more notable that straight-line acceleration… but There isn’t any point until there is power to put down.
Old Jan 11, 2009 | 11:30 AM
OCG35's Avatar
what size wheels?... and what tires are you currently using?... I have a set of 235/50/17 Kumho's with like new tread... they are way better then the Bridgestone I replaced for them, but not as good as the Toyos I replaced them with. If you don’t want to buy a new set and this size works for you let me know, I'll dump cheap.
Old Jan 11, 2009 | 11:38 AM
DaveB's Avatar
My car has a 52/48 weight distribution per the scales. It only does the one tire fire if the road is slick one side or I'm in a very very tight turn and lay into the gas. My Maxima had an open diff and it too laid down two perfectly straight patches of rubber.
The only situation where an LSD will really help you is on sweeping turns when the chassis unloaded and weight is coming off one of the drive tires. For the straight line, most LSDs don't react quick enough to deliver adequate traction to the spinning wheel. They do work, but when you're talking about the initial hit off the line, the LSD isn't going to catch it quick enough to improve a 60 foot time. Additionally, most LSDs can only transfer 20% to 40% of the power to the spinning wheel hence the term limited slip.
With my 18" PZeros, I hardly get any wheel spin unless its cold out. With my old 17" Avons, I could destroy them through 1st, feathering the throttle, and spinning a bit into 2nd. With my new 17" Falkens, I get spin, but not remotely as much. Both wheel setups spin the tires equally, with the tail kicking out a bit to the right, just like my old 94 Z28 with LSD. I can easily coax power oversteer at slower speeds as well, lighting up both rear tires. Just like my old Z.
Tires are the key. Grippy tires will quell all his off the line traction issues.
Old Jan 11, 2009 | 11:47 AM
Mustang5L5's Avatar
I meant left to right distribution more than front/rear. But it doesn't matter...the OP needs tires.
Out of curiously...what tires do you have on there 4-door? and what size?
Old Jan 11, 2009 | 11:09 PM
4drmadness's Avatar
i have michelin 215/55/17, with the stock 6 spoke rims. i pmed you OCG35
Attached Thumbnails getting a lot of wheel spin when flooring it-th_g35013.jpg
Old Jan 11, 2009 | 11:16 PM
06g35meister's Avatar
buy track tires, its the single most important thing you can do. I dropped over a second with tires alone (note, results may vary)
Old Jan 11, 2009 | 11:22 PM
Wannabe6MT's Avatar
-MN G Crew-
Damn i wish i could take off as dramaticly as that. With my 19s, the tires will chirp, IF that. I should toss the 17s back on some time and try doing a launch
Old Jan 12, 2009 | 12:04 AM
OCG35's Avatar
19s can do it... mine do
Old Jan 12, 2009 | 12:08 AM
Wannabe6MT's Avatar
-MN G Crew-
Mine dont lol
Old Jan 12, 2009 | 12:23 AM
OCG35's Avatar
Mine dont lol
get some that weigh 18.9 lbs
Old Jan 12, 2009 | 01:20 AM
DaveB's Avatar
On my 18s, I've got 235/45 Pirelli PZero Nero summers. They stick hard. The car is a completely different animal.
On my OEM 17s, I've got 215/55 Falken ZE-329s. They've only been on for about 3 weeks now, but they've been great for handling the cold weather and snow. I recently tried to do a hard launch with them in the 65 degree weather we had and they hooked up decently with just moderate spin.
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
DRG35R
Jul 31, 2015 10:23 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
itschuckster
Jul 25, 2015 08:07 AM
