Why is my car so slow?
Old Jan 10, 2009 | 09:47 PM
GT-ER's Avatar
I went to the track today and was shocked at how slow it was. I ran a best of 15.0@92mph. I have a Z-pipe and the stock resonator replaced by a shorter one ( exhaust is now audible vs. the stock nothingness ).
One thing I noticed is that the car is a total slug launching. I powerbraked to the highest permissable rpm and it still would launch very sluggish. Best 60' was a high 2.2. Stall speed seems to be kinda low ( maybe 2000ish? ) which I find to be too low for an engine with low rpm torque to begin with...
Is there anything that could be "wrong" with my car? I changed plugs and put a new stock replacement airfilter ( fram ) in it. I know it's not a K&N but I've had fram before with good results so I don't know what to think.
Any ideas?
Old Jan 11, 2009 | 03:11 AM
Texan1's Avatar
Q50 Red Sport 400 RWD
how many miles on your G?
are you running with vdc off?
are you on d or manumatic?
do you have a full tank or 1/4 tank or less of premium gas?
spare tire in?
are you heavy set?
are your tires bad?
Old Jan 11, 2009 | 06:46 AM
GT-ER's Avatar
Originally Posted by Texan1
how many miles on your G? 87000
are you running with vdc off? Tried off and on
are you on d or manumatic? Tried both ways
do you have a full tank or 1/4 tank or less of premium gas? Had about 1/8th of premium 93
spare tire in? yes, forgot to take it out
are you heavy set? If you mean me being fat then no...lol. I weigh 170.
are your tires bad? No, as a matter of fact they were so good I couldn't even chirp them off the line.
The car feels pretty strong but off the line it was the suck. Is 92mph good or bad for a near stock car?
Old Jan 11, 2009 | 10:33 AM
Wannabe6MT's Avatar
-MN G Crew-
Yea, thats pretty good trap speed.
Seems low though. You would think your in the high 14s.
Also, what elevation are you running at?
Old Jan 11, 2009 | 10:39 AM
PAIXAO's Avatar
That's a big one. Elevation, humidity, barometric pressure and air temp make a huge difference. Best thing to do is calculate your Density Altitude. I always do when I go to the track.
Old Jan 11, 2009 | 11:29 AM
Mustang5L5's Avatar
Wow, and here i was thinking i'd be happy to run a 15.0 in the spring with my G35.
Old Jan 11, 2009 | 11:35 AM
PAIXAO's Avatar
Also... next question is do you have aftermarket wheels? These will slow you down if they are heavier.
FWIW, I run mid-high 14's with my mildly modded 1992 Taurus SHO with 156k miles.
I know these cars are faster than that.
Old Jan 11, 2009 | 11:43 AM
DaveB's Avatar
What was the date, track, and city?
Every track is different. My 03 5AT did 14.3@98mph with a Z-tube, but the conditions were good (close to sea level).
Old Jan 11, 2009 | 12:25 PM
GT-ER's Avatar
See...that just makes me sad...LOL.
My track is in Carolina, PR. The Name is Carolina Speedway and the date was 01/10/09. I don't know how to get the track info though so I don't know the altitude and what not. PR is normally very humid as it is a tropical island but yesterday wasn't too bad.
As for the wheels...they are stock.
My previous car was a 2000 Pontiac Grand Prix GTP that bone stock ran exactly the same 15.0@92mph. The only difference is that with less than $1000 I ran 13.4@102mph...LOL. After that I added a nice turbo ( everything else stock ) and ran 12.6@111mph. Forced induction FTW!
Old Jan 11, 2009 | 12:27 PM
Mustang5L5's Avatar
I'd say PR is close enough to sea level that any correction factor is negligible.
Old Jan 11, 2009 | 12:28 PM
PAIXAO's Avatar
What time were you there yesterday? I can find the info for you...
Old Jan 11, 2009 | 12:31 PM
MyocyteX's Avatar
spare tire in?
are you heavy set?
are your tires bad?
Not a single question answered.....
Old Jan 11, 2009 | 12:47 PM
PAIXAO's Avatar
Using the oldest available readings from Carolina PR this is what I came up with:
At 1pm yesterday:
Altitude is 13ft
Air Temp was 82.9 degrees f
Barometric Pressure was 30.07
Dew Point was 69.1
Your Density Altitude is 1686 feet...
Meaning, the conditions were similar to those at 1686 feet. Not that big of a difference from seal level BTW.
Old Jan 11, 2009 | 12:48 PM
OCG35's Avatar
Any ideas?
I know its hard to accept (especially for some out here) – but launch off idle *for now*
Brake torque cuts power… I’ve been saying it forever, its finally been proven. I used Cipher at last track event and data-logged particulars that Up-Rev requested to diagnose issue… after sending the spreadsheet to them, they confirmed that the throttle is cut for a moment when the ECU recognizes the accelerator and brake are depressed at same time.
I’ve dealt with this for a looonnng time and determined 2-3 years ago that my 60; is actually better when launching off idle (even at 650-700rmp) than power-braking to 2-2.5K
The reason I said *for now* in first sentence is that Up-Rev is working on a solution… that was the whole reason I asked them to look at this issue… so we (AT) might be in business in the near future!
Edit: BTW - our stall speed is about 2500 and the trq converter isn’t that bad in these cars... I contemplated having trq converter re-built - but I'm waiting to see what Up-Rev comes up with the address the mention above. I think once the power cut issue is fixed, I can cut 60' times by .1 at least by launching around 2K even with stock trq converter.
Old Jan 11, 2009 | 12:51 PM
GT-ER's Avatar
I answered the questions....they are in bold.
