Weather Stripping
Old Jan 20, 2009 | 12:00 PM
MJION's Avatar
Weather Stripping
I have a feeling this is a common problem..
The weather stripping on my lower door panel is pealing..
Any quick easy reccomendations for this fix?
A good glue or replacement?
The dealer told me they don't have an easy fix for this which I think is BS!
Would that be covered under warranty?
Thanks!!
Old Jan 21, 2009 | 03:52 PM
xosder's Avatar
I had this problem occur a couple of weeks ago. Brought it to my local Infiniti dealer and they replaced the weather stripping on both rear doors. It was covered under warranty.
Old Jan 21, 2009 | 04:50 PM
Braintree's Avatar
If it's out of warranty, I've used Automotive Goop to hold my cars together.... it's today's transparent version of yesterday's duct tape. Extremely pliable, strong, easy to use, transparent and weatherproof. Just put it beneath the strip that's coming off, press the strip and hold it down with duct or masking tape, for about 2 hours and it should solve it. Just be sure then when it's pressed back into place, that it's original form is the same, otherwise it will leak in.
Freeman186
Sep 6, 2023 10:07 AM
rsingerG35
Accessories
Mar 16, 2016 01:41 PM
Learned Hand
Oct 1, 2015 09:02 AM
